dodge78 94 #1 Posted June 25, 2011 Looking through the service manual for a M18QS , I find this. What splined areas are they talking about? Is it the gear that is on the crankshaft? Are they talking about splitting the case to put some grease on it? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted June 25, 2011 They are referring to special internally-splined crankshafts that were used to drive direct-coupled hydraulic pumps. Example: It has nothing to do with the pressurized oil supply pump located inside the engine. :hide: Share this post Link to post Share on other sites
dodge78 94 #3 Posted June 26, 2011 I was tring to figure out where there would be 9 splines,. Thank you TT Share this post Link to post Share on other sites
