Operator 7 #1 Posted June 25, 2011 Any ideas on finding one for the rear PTO drive. # is 109829 or Toro no. P-3231 . My dealer says NLA, so now what? I tried finding an after market one and they are either too long or too short. A 1/2" by 146" is too short I've even tried putting smaller idlers to shorten things up but can't get enough belt. Any floating around? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,877 #2 Posted June 26, 2011 What about using a link belt? Going to be expensive but any 1/2" x 151-1/4" belt will be as that is what the 109829 belt is. Service bulletin 335 states illustrations 18 and 19 in the manual show the belts going to the wrong side after the mid-idlers resulting in the pto running backwards. The correct illustration is included. Garry Share this post Link to post Share on other sites
SAM58 33 #3 Posted June 26, 2011 Any ideas on finding one for the rear PTO drive. # is 109829 or Toro no. P-3231 . My dealer says NLA, so now what? I tried finding an after market one and they are either too long or too short. A 1/2" by 146" is too short I've even tried putting smaller idlers to shorten things up but can't get enough belt. Any floating around? Try this site... Gates Belts Part # Cross Over Type in your Wheelhorse part # and it will tell you the Gates number. If you know the actual length, and how wide, you can get it. whith across the back of the belt 1/2" = A Series 5/8" = B Series 3/4" = C Series the co. I work for is a GATES Dist and we special order belt for the oilfield all the time. I use them on my decks & mule drives Although, the Kevlar trans. drive belts come from a different divs. of Gates. On those, it is just as easy to check out Tractor Supply. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted June 26, 2011 Think you could make this one work? I did some serious digging and only came up with that one and a Toro #115-2649 - which is only 149.5" long X .5" wide ~ and a heck of a lot more money. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,877 #5 Posted June 26, 2011 At search at Stens for 154295 brings up another JD # 158130 replaced by Stens 265-313 - 1/2"x150". Garry Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted June 26, 2011 New lead........ Simplicity 1703372 (HA 151.00") I don't believe I can get any closer than that. :hide: Share this post Link to post Share on other sites
baerpath 517 #7 Posted June 26, 2011 http://www.wheelhorseforum.com/index.php?showtopic=11904 He didn't put a maker with it so not sure who made it Duane Share this post Link to post Share on other sites
Operator 7 #8 Posted July 4, 2011 Thanks Guys fo the leads! My parts guy told me from the 144" I got the next jump up is 150" so that is what I'll try. Gotta work. I want to get my rear mower on my C-195 soon. Thanks again. Share this post Link to post Share on other sites
refracman 167 #9 Posted July 4, 2011 Make sure you adjust the PTO exactly to specs, even then theres no guarentee that it'll hold. I do know the tiller is to much for it to hold even if the PTO lining is new. Let us know how it goes. Share this post Link to post Share on other sites
Operator 7 #10 Posted July 5, 2011 Mine had sat for some years before I hooked up tiller, belt was bent in the wrong places. Specs? Share this post Link to post Share on other sites
refracman 167 #11 Posted July 5, 2011 Yup either its in the manual or as a seperate sheet. I had a heck of time just getting the PTO to hold for the deck, thats until I read the directions. Hmmm imagine that I'll see if I can find it and scan /post it. Share this post Link to post Share on other sites
refracman 167 #12 Posted July 5, 2011 Heres the directions from the manual. Service bulletin # 335 that Garry is refering to is in yahoo wh manual group #8 Share this post Link to post Share on other sites
buckrancher 2,695 #13 Posted July 5, 2011 you can get a super A150 belt off e-bay it's 152" long Brian Share this post Link to post Share on other sites
shorts 182 #14 Posted July 5, 2011 IIRC, belt sizes are measured by the root dia of a standard size pulley, the root dia is the pulley dia at the inside of the belt so the belt will actually measure around the outside about 2'' longer than the label length Share this post Link to post Share on other sites
