Anglo Traction 761 #1 Posted June 24, 2011 I have a Handy Cultivator that is also good for ripping roots or seed trenching. It can be used with a Clevis or Slot Hitch, but I need to 'Beef Up' the lift linkage. I can't find a Model number and wonder if anyone can I.D. it?. It will be used for a while first, then give it a full clean re-paint. Any help would be appreciated. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted June 25, 2011 Try 7-1722 (or 7-1723) for the model number. Note: What you have pictured above is only the rear section of the two piece set. Share this post Link to post Share on other sites
Anglo Traction 761 #3 Posted June 27, 2011 Thanks for the response Terry, a great help!. Look's like there are a few Tines missing as well. It will do for what I need it for, then maybe Fab one up for the Mid Hitch if necessary. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted June 27, 2011 Look's like there are a few Tines missing as well Technically - no. The rear section I have pictured actually has all 9 shovels from the entire set mounted to it. (how I bought it) The front section in my pictures is from a different set and has the correct amount of standards & shovels (normally, there were 5 shovels on the rear and 4 on the front section) My other set (with home made front section) that I have on my Charger is set up "correctly": Share this post Link to post Share on other sites
Anglo Traction 761 #5 Posted June 27, 2011 That's good news, thankyou Terry. On your Charger, is the Lift Linkage to your Slot Hitch Standard and the Cable running through the Flexible type Conduit?. I can't find a Cable Conduit for my '74' C-120 rebuild over here, let alone a Cable Kit, so I will have to make it.... Just wondering if the standard linkage copes ok . Regards. Share this post Link to post Share on other sites
