jus97tin 0 #1 Posted June 21, 2011 My 1967 1077 wheel a matic is leaking bad out if the rear end. I had the pump gear drive off of the side bacause I thought that i had to replace an inner bearing. Turns out I didn't have to so I put it back together but the gasket/seal that went between the axle housing anf the pump riped on the bottom. i trying to used a gasket sealer and reuse the old gasket and it worked of a while but then it started to leak out all over the garage floor. I apears that the do not reproduce the gasket that i need so what is the best fix for this. The tractor does move with no problems other that the fact that it not doesn't hold the rear end fluid. Share this post Link to post Share on other sites
rmaynard 16,588 #2 Posted June 21, 2011 I don't know how intricate the gasket is, but you can buy gasket material at most auto parts stores and try making a new one. Share this post Link to post Share on other sites
can whlvr 994 #3 Posted June 22, 2011 i did as bob said on my c160,i took my time and used a very sharp xacto knife and it turned out fine Share this post Link to post Share on other sites
