jtmoyer 1 #1 Posted June 20, 2011 I picked up a 416-8 with an onan twin a few years ago in poor shape, but it ran. I was in the process of getting to going tonight to use the tank sprayer I mounted on the back when the engine took a crap. I robbed the fuel pump a few weeks ago for the Share this post Link to post Share on other sites
VinsRJ 723 #4 Posted June 21, 2011 Sorry for your loss.... :hide: Share this post Link to post Share on other sites
312Hydro 474 #5 Posted June 21, 2011 Say it ain't SO! Share this post Link to post Share on other sites
Save Old Iron 1,571 #6 Posted June 21, 2011 remember the old saying "mostly dead means somewhat alive" we can fix it - make it better - we have the tools, the technology ..... Share this post Link to post Share on other sites
liketoplayto 6 #7 Posted June 21, 2011 Another loss to the hoosier state wow seemed like a nice tractor that fought till the end :hide: Share this post Link to post Share on other sites
bigd 0 #8 Posted June 21, 2011 :hide: such a sad day.but i believe in resurrection so lets get the ball rolling.Iworked on a kawasuckie last year that did the same thing after a long bout of cussing and much head scratching.it turned out to be a carb problem.you do have one symptom that i did'nt the firing about every tenth time and picking up speed that suggests timing to me or a major vacuum leak.bring it back im curious now. Share this post Link to post Share on other sites
tunahead72 2,581 #10 Posted June 21, 2011 I may be missing something here, and I'm certainly no expert, but when I read your post, the first thing I thought was ... So, other than the fact that your engine's not running right now, why exactly are you calling it dead? I'm with save_old_iron and bigd, this old engine may still have some life in it, can't hurt to try a few things. I'd start with the fundamentals, look for obvious stuff like a closed fuel shutoff valve and bad electrical connections, check the timing and look for vacuum leaks like bigd suggested, let everybody here know what you find, and take it from there. Just my 2 cents worth, others will have more specific ideas, hope you can get it running again! :WRS: Share this post Link to post Share on other sites
Save Old Iron 1,571 #11 Posted June 21, 2011 wise words from the talking fish .... remember you may not be able to tuna fish but you sure can tuna carb ! Share this post Link to post Share on other sites
pharmer 0 #12 Posted June 21, 2011 Maybe it was all the cursing done earlier! Share this post Link to post Share on other sites
SousaKerry 503 #13 Posted June 21, 2011 Sounds like fuel or timing to me, my old trick to finding out if it's a carb problem is if I can run it on either or not (just don't run it too long or you will scrub the cylinder walls of oil) back on the farm we used to put gasoline in a spray bottle and spray it in the carb while trying to start them. Heck I've even used WD-40 to run an engine. :hide: Share this post Link to post Share on other sites
Toejam 1 #14 Posted June 21, 2011 I am with the other guys. Its my opinion that if there isn't a rod sticking out the side or something similar then the motor is not dead. Keep looking into it she will live again. Share this post Link to post Share on other sites
bo dawg 536 #15 Posted June 22, 2011 Stratle that baby and smack it's a few times she'll come around. Even the hospitols uses those electrol shock pads on people to jump start them. Share this post Link to post Share on other sites
bo dawg 536 #16 Posted June 22, 2011 Dont start singing "another one bites the dust" yet bro! :hide: Share this post Link to post Share on other sites
shorts 182 #17 Posted June 23, 2011 you said it has 90 psi comp, check for spark new sparkplugs and get out the small pump oilcan full of fresh gas and revive the old horse. It seems from reading here that the onan carbs are sometimes a little finicky but not impossible to work with. Share this post Link to post Share on other sites
bigd 0 #18 Posted June 23, 2011 a little finicky is not the description for onan carbs the they are the divas of the carb world.Lord help you if there is a tiny speck of dust somewhere they will make you life miserable Share this post Link to post Share on other sites
farmer 1,081 #19 Posted June 23, 2011 I have an Onan in my 518, when it sometimes plays silly bu@@ers my wife calls me The Galloping Major on it........I can't type what I call it. Onan's... I'm fast developing a hate/hate relationship with it. :WRS: Share this post Link to post Share on other sites
jtmoyer 1 #20 Posted June 23, 2011 gave it another look tonight. oil in the cylinders after setting for a few days. don't have time to do a rebuild, must move on to other projects. any one else feel like life it just one project after another. guess if i ever get them all finished i will have time to die. :WRS: Share this post Link to post Share on other sites
bigd 0 #21 Posted June 24, 2011 what you gonna do with it? Share this post Link to post Share on other sites
shorts 182 #22 Posted June 24, 2011 you haven't seen finicky carburaters untill you survive the 4 weber DCOE sidedraft nightmare on a vintage sportscar Share this post Link to post Share on other sites
shorts 182 #23 Posted June 24, 2011 :hide: you haven't seen finicky carburaters untill you survive the 4 weber DCOE 2bbl sidedraft carb nightmare on a vintage sportscar :hide: Share this post Link to post Share on other sites
WH nut 553 #24 Posted June 25, 2011 Id put a set of plugs in it, 90 psi isnt so bad Share this post Link to post Share on other sites
AMC RULES 37,234 #25 Posted June 25, 2011 Or just put a bullet in it. :hide: Share this post Link to post Share on other sites
