zertwizchris 0 #1 Posted June 19, 2011 hi i just aquired my grandfathers c 121 auto and its got a hydrostatic trany theres supose to be a nut or bolt to lusen to alow the weels to turn but i cant seem to find it can any one help chris anderson Share this post Link to post Share on other sites
Kilroy 0 #2 Posted June 19, 2011 it is a small square headed bolt that takes a 3/16" wrench (i think). If you look between the fender/seat pan and the rear tire you will see it pointed towards the front of the tractor, coming out of the trans. If you remove the left rear wheel getting to it is a lot easier (at least for me it is). good luck. loosen this bolt to push the tractor. Don't forget to tighten it back up when you are ready to drive it. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted June 19, 2011 Follow this link to a picture of the hydro unit bypass valve location: http://www.wheelhorseforum.com/index.php?showtopic=28447 Share this post Link to post Share on other sites
zertwizchris 0 #4 Posted June 19, 2011 thanks a bunch that shuld help some one draged the thing with a can about a half mile i hope it dident damabe any thing. Share this post Link to post Share on other sites
dennist 139 #5 Posted June 19, 2011 I do not think you should be dragging it with a car. You can do damage by doing this. Share this post Link to post Share on other sites
