dodge78 94 #1 Posted June 19, 2011 Is there a big difference between the Kohler fuel pumps and the aftermarket ones? other than $20? Its for the 418. tom Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted June 19, 2011 Other than the packaging, I'm going to say no. They're all plastic now - and probably made by the same company in China or Japan. If an OEM aluminum pump interests you, I might know someone who has a new one. Does your fuel pump look like this?: As-is / no box. $45 shipped..... PM me if you're interested. Share this post Link to post Share on other sites
dodge78 94 #3 Posted June 20, 2011 Well I found out its was not the pump. There was a hole in the fuel line I put on about one month ago. The hole was between the block and the frame, no where near any thing to put a hole in it. No smell pf gas. I am stumped on that one. TT, thanks for the offer. but it look like I wont be needing one. Maybe I should pick on up just because, how long will that sit on a self before it drys out? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted June 20, 2011 It should be good as long as no gas is run through it. I should probably vacuum seal some of this stuff though. Share this post Link to post Share on other sites
rmaynard 16,873 #5 Posted June 20, 2011 Is it my imagination or is the top installed 90 degrees off? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted June 20, 2011 Is it my imagination or is the top installed 90 degrees off? You're seeing it right. Easy way to ID the pumps for KT & M series twins. :hide: Share this post Link to post Share on other sites
tunahead72 2,617 #7 Posted June 21, 2011 There was a hole in the fuel line I put on about one month ago. The hole was between the block and the frame, no where near any thing to put a hole in it. No smell pf gas. I am stumped on that one. Mice? :hide: Share this post Link to post Share on other sites
