tarcoleo 119 #1 Posted June 15, 2011 Is it true that Geico can save you 15% on your car insurance? Do smart Wheel Horse owners remove the grease fitting on the primary (center) deck spindle except when greasing it? Tom in RI :hide: Share this post Link to post Share on other sites
sgtsampay 117 #2 Posted June 15, 2011 I am now since I have lost 2 fitting that way on my 48iner. LOL. Share this post Link to post Share on other sites
daemon2525 5 #3 Posted June 15, 2011 OK, I'll bite. Why take it out? Share this post Link to post Share on other sites
sgtsampay 117 #4 Posted June 15, 2011 I had to leave mine out cause on my 48in, the middle spindle fitting hits on the lift bar and then the fitting is grounded off. If the fitting is taken off, then the clearence is just perfect. Share this post Link to post Share on other sites
chazm 413 #5 Posted June 15, 2011 WOW !!! Tom, can you really save 15% on car insurance How much can you save on tractor ,boat ,home, motorcycle or rental insurance Is it still 15% ?? Can you bundle for a bigger %%% And where does that freakin lizzard keep his wallet & cell phone anyway Chaz :disgust: Share this post Link to post Share on other sites
danjmah 74 #6 Posted June 15, 2011 I had the same issue. I resolved it by adding a couple of washers which pulled the lift bar over and away from the center spindle. 1 Share this post Link to post Share on other sites
dmoore 962 #7 Posted June 16, 2011 Is this only a problem on the 48" decks or 42" also? Share this post Link to post Share on other sites
MalMac 1,332 #8 Posted June 16, 2011 It's close on my 42 and on my 48 I have had the same problem. It has knocked it off several times. I ended up just taking it out. Putting it back in to grease. The washer thing looks like a good option. Share this post Link to post Share on other sites
IthacaJeff 151 #9 Posted June 16, 2011 I guess it is nice to know that others have the same problem. I've knocked out a bunch of the center zerk fittings and now I go zerkless. Maybe I'll try the washer thing as I've got to take the deck off today and figure out why I was getting sparks on the right side deck pulley. Not a good sign! Jeff in Enfield NY Share this post Link to post Share on other sites
tarcoleo 119 #10 Posted June 16, 2011 Neat solution Daniel. Thanks. Tom in RI :hide: Share this post Link to post Share on other sites
can whlvr 994 #11 Posted June 17, 2011 ive lost lots too on tha 42 side discharge Share this post Link to post Share on other sites
Shuboxlover 480 #12 Posted June 17, 2011 Was this an oversight by the engineers??? Share this post Link to post Share on other sites
tarcoleo 119 #13 Posted June 17, 2011 Daniel- Your photo of the washers/hairpin solution gave me an idea that a washer/shaft collar arrangement might also work. Tried it and it does. Tom in RI :hide: Share this post Link to post Share on other sites
Don1977 605 #14 Posted June 17, 2011 I have a fitting in mine that has the top wore off. I just remove it install a good fitting to grease it ,then put the old one back into keep the trash out. Share this post Link to post Share on other sites
