WH Raider10 17 #1 Posted June 12, 2011 Hi everyone, The carburetor on my 312-8 is leaking pretty bad. I'm looking to find the correct carb kit I need to do a rebuild on the carb. I've seen different kits for sale for my carb but I need to be sure which one I need. The carb is a walbro with fixed main jet. The engine is a Kohler Magnum 12 HP. Can someone give me a link to the correct kit I need? Thanks, Pieter-Jan :hide: Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted June 12, 2011 Hi Pieter, I am seeing what you are and came away confused. I saw no available kits for a Kohler carb. There are kits for what looks like a fixed jet but they don't mention the manufacturer. It may help our experts here if you have a year and serial number of the tractor and the Spec Number of the magnum engine. Sorry I couldn't help! BooVuc Mill Hall, PA Share this post Link to post Share on other sites
tunahead72 2,546 #3 Posted June 12, 2011 What BooVuc said makes a lot of sense, looking for model/serial/spec numbers on the tractor and engine. But it may also be possible that your Walbro isn't the original carb on this engine, I would look for identifying marks and numbers on the carb itself, maybe just inside the throat and elsewhere, might give you some clues. Good luck! Share this post Link to post Share on other sites
Anglo Traction 761 #4 Posted June 14, 2011 Hi Pieter-Jan, I agree with the guys here. Check your Carb first. All serial and Model number info is stamped on the Bolting Flange, either on top or underneath. I don't believe there is any difference in the contents of a Kohler/Walbro Carb Kit for either Fixed or Adjustable Main Jet Needle Carbs . I have found a place in the UK for you that sells Genuine Kohler/Walbro Carb Kits for Magnum 12s, but not sure if they ship outside UK?. They also charge UK Share this post Link to post Share on other sites
WH Raider10 17 #5 Posted June 15, 2011 Thanks for the info and help Richard! I appreciated it! :hide: Share this post Link to post Share on other sites
