papaglide 542 #1 Posted June 11, 2011 well I bought a nice 416-8 and noticed that when starting in 2 or 3 gear the clutch kind of sticks and she kind of does small wheelies when starting out. It is a 1997 and has the gas dampener on it. How do I adjust the clutch to eliminate these wheelies and whiplash as well? Thanks....pics coming soon! :hide: Share this post Link to post Share on other sites
Retired Wrencher 6,062 #2 Posted June 11, 2011 :hide: it is all in the clutch adjustment rod. that ties in with the brake. the pedal should go down about 1/2 way to the fan shroud I had the same issue this spring with my 1057. did some fiddling with till it ran smooth. t/care Gary B............ Share this post Link to post Share on other sites
VinsRJ 723 #3 Posted June 11, 2011 Im not seeing the problem.... I try to pull wheelies all the time :hide: Share this post Link to post Share on other sites
Stigian 1,234 #4 Posted June 15, 2011 Sometimes wheelies just happen.. Though I think the weight of the roll bar might of had something to do with this Share this post Link to post Share on other sites
BOWTIE 226 #5 Posted June 16, 2011 HELLO, YOU MIGHT LOOK AT THE IDLER PULLEY. I HAD THIS PROBLEM WHEN THE BEARING WAS GOING BAD. THE PULLEY WOULD NOT SPIN, THEN ALL OF A SUDDEN IT WOULD LET LOOSE. BOWTIE IN OHIO Share this post Link to post Share on other sites
