bo dawg 565 #1 Posted June 11, 2011 Changing the oil and filter in the 82 C-175 trans/rear. Is there any other drain plug than the one on the very bottom of case? Chart shows 5 qts empty but I dont think I drained quite that much. Although the rear is a lot smaller than my C-161 but both holds 5 qts. My other tractors I've had all had 2 drain plugs. Share this post Link to post Share on other sites
stoneman 10 #2 Posted June 11, 2011 I'm thinking that you need to run it enough to get the new filter filled up. That's close to 1/2 a quart, and maybe that'l put where you need to be. I doubt that there's another drain plug, but do you have any hydro lines that may have fluid in them? :hide: Share this post Link to post Share on other sites
bo dawg 565 #3 Posted June 11, 2011 I haven't tryed filling it up yet, drained it out last night but didn't get 5 qts out. Oh well I'm going to put the new filter on and filler up and see what happens. :hide: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted June 11, 2011 Total system capacity is always greater than routine change. All of the oil does not drain completely out of the pump/motor unit, lift control valve/lines/cylinder, etc. so less than five quarts in the drain pan isn't abnormal. If you don't already know how much of a PITA these are to refill because they airlock, either pump the oil in through a hose smaller than the dipstick tube, or remove one (or both) of the fender support mounting bolts on top of the transaxle. Share this post Link to post Share on other sites
bo dawg 565 #5 Posted June 12, 2011 Total system capacity is always greater than routine change. All of the oil does not drain completely out of the pump/motor unit, lift control valve/lines/cylinder, etc. so less than five quarts in the drain pan isn't abnormal. If you don't already know how much of a PITA these are to refill because they airlock, either pump the oil in through a hose smaller than the dipstick tube, or remove one (or both) of the fender support mounting bolts on top of the transaxle. Thanks TT, thats what I was betting on. You're so right about the air thing. Share this post Link to post Share on other sites
