jasoncracer 0 #1 Posted June 9, 2011 my c160 inside the bowl has a line like.if the fuel sat there and ate it away tractor runs great new plug,points one problem getting a little spudder every once in a while carb is clean no play in shaft clean filter. whats that line could that cause a spudder or maybe a bad bowl seal I fine adjusted carb for hours no luck? Uploaded with ImageShack.us Share this post Link to post Share on other sites
Jim_M 179 #2 Posted June 9, 2011 No offense intended, but from the look of that bowl the carb is not clean. I would take it apart and soak it in carb cleaner overnight, blow it out, reassemble it and try it again. Share this post Link to post Share on other sites
jasoncracer 0 #3 Posted June 9, 2011 Will try the stuff on bottom of.bowl.wont come.off also if you look at high idle needle.valve from bowl.side as you turn it its not 100% straight will that do it Share this post Link to post Share on other sites
smoreau 658 #4 Posted June 9, 2011 I agree with Jim M on this one, that bowl isn't clean. It should be all aluminum insde, not black stuff. I bought a 1 gallon can of dip carb cleaner with a basket in it for $15 from O'Riellys and have cleaned 5 carbs with it and the come out spotless after 24 hours. It has paid for it self in the amount of carb spray I have saved. Best of all the can is still full and should be able to clean many more carbs. Share this post Link to post Share on other sites
jasoncracer 0 #5 Posted June 9, 2011 Thanks working at toro now they have this system it vibrates its got a solution in it heats up. leave carb in it for a little looks like new when its all done. Share this post Link to post Share on other sites
Shuboxlover 481 #6 Posted June 9, 2011 Thanks working at toro now they have this system it vibrates its got a solution in it heats up. Congrats on the job....are you talking about an ultrasonic cleaner??? If so, we use those at work to clean some of our parts that are particle sensitive, they do a FANTASTIC job!!! :hide: Share this post Link to post Share on other sites
shallowwatersailor 3,214 #7 Posted June 9, 2011 HF sells a nice ultrasonic unit that is not too expensive. It works wonders on what you need cleaned. Share this post Link to post Share on other sites
wheelhorsec85 5 #8 Posted June 9, 2011 my c160 inside the bowl has a line like.if the fuel sat there and ate it away tractor runs great new plug,points one problem getting a little spudder every once in a while carb is clean no play in shaft clean filter. whats that line could that cause a spudder or maybe a bad bowl seal I fine adjusted carb for hours no luck? Uploaded with ImageShack.us JASON JUST BUY A NEW BOWL . that bowl is garbage . once they get eaten through like that it will continue to happen . new bowls are cheap :WRS: Share this post Link to post Share on other sites
.5racer 14 #9 Posted June 10, 2011 What did you set the points at ? CLEAN that bowl with steelwoole and blast that carb with some cleaner, with a new carb gasket set and reassemble, adjust and set . Good Luck :hide: Share this post Link to post Share on other sites
shorts 182 #10 Posted June 10, 2011 the ring around the bowl is from a combination of water and hi alcohol content gasohol being left in the carb foe an axtended period, kinda like not draining the carb when winterizing ,been there done that,more than once anyhow,replace the bowk,check the float for damage from being frozen"partially collapsed/crushed" replace it also if necessary, check and thorougly clean the hi speed jet and fuel pickup passages in the stem that the bowl bolts to. sometimes a quick soak in vinegar and then baking soda solution will clean out serious corrosion in a carb. then clean with carb spray and compressed air before assembly Share this post Link to post Share on other sites
can whlvr 994 #11 Posted June 11, 2011 i too have used the ultrasonic cleaners,they work unbeileivable,it vibrates and heats up hot soapy water i did my 30 year olr sthil weedwacker and it runs like new,i borrowed it and would buy one in a flash,the one i used was about 500 bucks,but for that much cash a can get more horses Share this post Link to post Share on other sites
72morph 1 #12 Posted June 11, 2011 Please check point gap as it cost me a lot of money and aggravation. Try 15 to 18 . Share this post Link to post Share on other sites
puddlejumper 67 #13 Posted June 11, 2011 Not to disagree with everybody because its all valiod points. But you have done this several times and you say its clean maybe stained but clean. Your occasionall miss could be a faulty spark plug or condensor. OR even a plug wire shorting occassionally. I know you said you replaced these items but stranger things have happened. Share this post Link to post Share on other sites
tommy3horse 3 #14 Posted June 11, 2011 Hello Jason; Kohler has the points set @ .020, plug @ .025. Main needle must be VERY clean too. Good luck. Tom :hide: Share this post Link to post Share on other sites
