fourwheels0 191 #1 Posted June 7, 2011 what chains are good for a c-81 or a charger electro 12. i believe they both have the same tire size but not positive. i'm not sure about the way chains are described in ads what size i need and which chains are good and which ones to stay away from. any info would be great. thanks. Share this post Link to post Share on other sites
fourwheels0 191 #2 Posted June 7, 2011 i found a set of max trac chains. 2 Link V-Bar Max Trac Tire Chains. 25" x 8" x 12". 55" Long & 13" wide. would these be good and fit a c-81 or charger electro 12. Share this post Link to post Share on other sites
COMMANDO1 23 #3 Posted June 7, 2011 If they fit use them.......... Share this post Link to post Share on other sites
fourwheels0 191 #4 Posted June 7, 2011 well i don't know if they'll fit. i'm not gonna buy them if they don't fit. my tires are 23x8.50x12. what does the 8.50 refer to? Share this post Link to post Share on other sites
JUSS10 250 #5 Posted June 7, 2011 23 is the tire diameter, 8.5 is the tire width, 12 is the wheel diameter somebody correct me if I'm wrong Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted June 8, 2011 Justin your correct, I like 2 link, V bar are nice but not if you have nice cement or asphalt driveways they chew them up. Share this post Link to post Share on other sites
can whlvr 994 #7 Posted June 8, 2011 i have 2 link,4 link and 2link vbar and also 4 linkvbar,the 2 link vbar are the best for traction,i got the others with tractors or found them but if i was gonna buy,2link vbar and get the chain size for your rears,the 25-8-12 should fit,if they are long a little you take out a few links and sometimes a cross chain too Share this post Link to post Share on other sites
fourwheels0 191 #8 Posted June 8, 2011 ok thanks. i think i'm gonna get the ones i'm looking at. Share this post Link to post Share on other sites
