skrusins 128 #1 Posted June 7, 2011 I never owned a WH with a hydro, and not sure what to expect. I have a Kubota zero turn and when going from forward to reverse it doesn't jerk or jump, it really does tear up the grass though. I'm hoping that it's me, but when I mow with my WH if I shift from foward to reverse it make a stop. Then when I shift forward it to lunge or buck. When I go down hill it wants to go fast and I have to pull back on the lever. Going uphill I have to keep the lever up to make it up. I been reading and enjoying your site, very informative and great group of members. I notice that there is and alot of members that have hydros. I hope I'm doing something wrong and get some help, or is this common. Thanks in advance Share this post Link to post Share on other sites
can whlvr 994 #2 Posted June 7, 2011 :hide: my hydro does not lunge forward unless i push the lever too fast forward,but if you use smooth action it is smooth,and yes the hydros wander down hill,and i have to give her more lever going uphill Share this post Link to post Share on other sites
skrusins 128 #3 Posted June 7, 2011 Thanks Don, The wandering up and down information helps me alot. I do feel like I use a smooth action, but maybe not smooth enough. Thanks reply really helps. Share this post Link to post Share on other sites
rick 310 #4 Posted June 11, 2011 My 416H speeds up going downhill, and slows going uphill. It will jerk when the lever is moved rapidly, due to the "dynamic braking" feature built in to the Eaton 1100 hydro. I have learned a soft touch alleviates the jerking when moving the stick. I can slide the tires easily on the smooth concrete floor when rapidly slowing down from full speed. Share this post Link to post Share on other sites
skrusins 128 #5 Posted June 12, 2011 Thanks Rick, That is good helpful information. At least is isn't me. I originally thought I had something adjusted wrong, and didn't know what to expect. You and Don good help. Thanks Share this post Link to post Share on other sites
