Countdown To Christmas!
Horse'n Around
Seat springs for a Raider question
Horse'n Around
I have been thinking about installing a set of seat springs on my 1970 Raider 10. What model WH would have the springs that would also work on my Raider? I saw someone else added some to their tractor and it got me to thinking again about adding some to my Raider to make it more comfortable . Ever since I broke my back, every little bit helps... a lot :hide: Here's a pic of it as it sits now so you will know what I have to work with. Im pretty sure the seat is original to it. My friend reupholstered it for me a while back. When I got the tractor, it had been sitting in the sun for at least 5 years and there was basically no vinyl left on it anywhere . He did a really nice job on it.
Thanks for any suggestions you can give me,
John
Kelly
A set from any WH should fit, except ones that have slide adjusters they are drilled with a diff. patern, I have some if you need them.
Horse'n Around
Hi Kelly, Yes Im interested,PM sent.
Thanks
Gerry w
Your going to love adding springs to your raider, it really makes a difference. The only downside to it is your seated higher, and getting on and off is different. But as I remember from the show your a taller guy than I, (as are most!) and my problem shouldn't be yours! :hide:
