jasoncracer
Manual lift assist I came up with
buckeye
That's a good one... I like it. :hide:
jasoncracer
It helps alot thank you!
Horse'n Around
Thats a great idea Jason :hide: I think Ill make one too.
John
Horse'n Around
Thats a great idea Jason :hide: I think Ill make one too, my snow plow is a bit heavy, I think this would help a lot.
John
jasoncracer
Thanks john I went in plumbing section at home.depot its a.pipe clamp I.believe 1/2 or 3/4 inch with one hole with threads then used an I hook.
W9JAB
That conduit clamp does not look like it will hold up very well.
I did the same sort of thing but opened up the end of the
spring and hooked it over the cross bar.
jasoncracer
Clamp is very strong including I have I bolt taped into the rod.
