Cody 283 #1 Posted May 31, 2011 Yesterday i bought a package deal of wheel horse stuff and this NOS pulley assembly was in with everything but im not sure what it is or used for. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted May 31, 2011 Some of it looks familiar - like the pulley. I know it was used on the RT-367 tiller, but on a different bracket that mounted near the back of the frame. That mounting plate is drilled with the same pattern for the mid-hitch and would place the pulley directly under the PTO pulley on the engine, but I still can't place what attachment it would have been used to power. :hide: Share this post Link to post Share on other sites
mavfreak 11 #3 Posted June 1, 2011 Some of it looks familiar - like the pulley. I know it was used on the RT-367 tiller, but on a different bracket that mounted near the back of the frame. That mounting plate is drilled with the same pattern for the mid-hitch and would place the pulley directly under the PTO pulley on the engine, but I still can't place what attachment it would have been used to power. wow TT is stumped! Share this post Link to post Share on other sites
puddlejumper 67 #4 Posted June 1, 2011 Could it have been used as a reduction gear to change pulley speeds for use with maybe a hay elevator or other farm related stationary Item that just used a engine driven pulley. If memory serves we just had a 6 horse on the hay elevator when I was a kid to put hay in the barn loft. Share this post Link to post Share on other sites
Cody 283 #5 Posted June 1, 2011 TT is correct because the bolt holes do line up with the mid hitch. This has me stumped also, i have looked through every book i have and not been able to come up with a picture of it or anything close. Share this post Link to post Share on other sites
Cody 283 #6 Posted June 1, 2011 Could it possibly be some sort of old style tiller pulleys for tractors before 1973? On one end of the flat bar a idler pulley would be mounted and the other end for a spring to tension the belt. :hide: Share this post Link to post Share on other sites
tunahead72 2,621 #7 Posted June 2, 2011 Can't quite read them from my house , but that outer pulley seems to have a couple of numbers stamped into the surface, maybe those would give somebody a clue? Share this post Link to post Share on other sites
312Hydro 474 #8 Posted June 2, 2011 I'll take a guess, 7354 ? Share this post Link to post Share on other sites
c175inMA 8 #9 Posted June 3, 2011 http://www.wheelhorse.org/phpBB3/viewtopic...t=152&view=next :hide: Share this post Link to post Share on other sites
Cody 283 #10 Posted June 12, 2011 Wow very interesting, that sounds like the pulley i have. Does anyone have a manual for the 7-1211 tiller. Perhaps the manual would have a picture of the pulley setup. Share this post Link to post Share on other sites
jusjeepn 59 #11 Posted June 12, 2011 Your pulley set up is not used on the 7-1211 tiller set-up. It used the same mid mount idler set up that most all other tillers use but also had a jack shaft that mounted to the transmission mount plate on the frame. It used a dual belt set-up, an extra belt guard and a rear hitch that was exclusivly used for that model tiller. I have that model tiller but not the jack shaft or the belt guard. There is a member here that does have the complete set up that lives close to us but I'm not sure if it's for sale (Ron?). I'd be interested in that pulley and mount if you want part with it! P/M me! Share this post Link to post Share on other sites
520HC 208 #12 Posted June 12, 2011 Is this what you all are discussing? Share this post Link to post Share on other sites
Cody 283 #13 Posted June 12, 2011 Yes i have that older model tiller also but am missing the idler pulley and jackshaft assembly. So we can scratch off the possibility of it being used on that tiller. Does anyone have an idea on what this pulley assembly is used for??? 520HC nice setup :hide: Share this post Link to post Share on other sites
