tmcgoo 0 #1 Posted May 29, 2011 i have a1973 12 automatic, the tiller for this unit is # 7-1252. in all the manuals it says that model #77-36tl01 is the replacement model for this tiller.this is the model i just bought, in brand new condition. in some of the manuals it says i need a service assembly #105105 to mount this to my tractor.the problem i am having is with the rear lift lever mounting. i don't have a rear lift lever support bracket. even if i did, the manual pictures show a supprt bracket that will not fit my tractor. does anyboby have any ideas on how to attach my rear lift lever to my model tractor without me just trying to build a rear support bracket, and what is service assembly #105105? if there are parts available to do this, does anyone know wher i can get my hands on these parts? thanks in advance Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted May 29, 2011 The lift lever assy DPES NOT APPLY to your 1973 tractor. All you need to do is run a cable thru the cable tube from the bottom of the lever used to raise the mower deck to the tiller. the cable and tube (conduit) would look like this Attached Image Share this post Link to post Share on other sites
tmcgoo 0 #3 Posted May 29, 2011 i guess the other end of the cable goes to the lift chain connection on the tiller itself and what is the connecting bracket in the middle of the picture you attached, i guess you adjust the lift of the tiller by changing the length of the cable. Again thanks Share this post Link to post Share on other sites
