BPjunk 184 #1 Posted May 23, 2011 Well it may look like a lynching but it ain't ..... I've been working on my trailer when free time comes up and came up with this small crane for working on the Wheel Horses. I came across a pick up truck crane at the local flea market for 10 bucks, it was missing the base, the winch worked so so and the cable was incorrectly routed ...... but for $10.00 it was not going home in some one elses car ! A 4 foot section of 3 inch pipe was welded to a 3/16 plate on the frame of the trailer and then the pipe ran through a second plate that was welded to the top rail. Some holes were drilled in the top of the pipe so the crane can pivot around or be pinned in one direction when in use. The hydraulic jack lifts the arm up whilst the winch picks up the load. The winch was on the front of the trailer and now has been replaced with a UT- 3000 lbs Superwinch (the UT-3000 Superwinch was made in China and I would not have bought if I knew that). A Tuff Tug ****** block and Crosby 1 ton hook complete the winch. This crane set up has a lift capcity of 1,000 lbs depending on the lenth of the crane arm. After the first try at lifting a model 552 with snow plow I found the trailer would tilt over so a 1,000 lbs trailer jack was bolted to the side of the trailer for support when lifting. For the test I wrapped a 1/4 chain around the front axle of the 552 then jacked the arm up and winch the 552 right off the ground. The 552 moved easy when manuvering the crane because there is a grease fitting at the top of the mount. Wild Bill in Richmond, Va. Attached Image Share this post Link to post Share on other sites
Sparky-(Admin) 23,779 #2 Posted May 23, 2011 "Hang em high!" Looks like a good setup Bill . Allways nice to hear from you. Mike....... Share this post Link to post Share on other sites
bitten 134 #3 Posted May 23, 2011 Looks like something you would do to a deere :hide: Share this post Link to post Share on other sites
c175inMA 8 #4 Posted May 23, 2011 Looks like something you would do to a deere :hide: Share this post Link to post Share on other sites
fireman 1,022 #5 Posted May 23, 2011 That's awesome Bill I have one of those cranes left over from a project I was working on for someone. You've inspired me to finally do something with it! Share this post Link to post Share on other sites
Duff 206 #6 Posted May 23, 2011 Dang, Bill, that's one nice set-up. Whereya been, buddy/ We've missed you! Duff :hide: Share this post Link to post Share on other sites
SALTYWRIGHT 861 #7 Posted May 23, 2011 BILL YOU WILL SEE MY CRANE ON THE BACK OF MY 417-8-DIESEL AT THE BIG SHOW IN PA. RUSS Share this post Link to post Share on other sites
C-Series14 15 #8 Posted May 24, 2011 Welcome to RS, Bill! Nice to have a new face around here!!! Glad to hear from ya, Wild Bill.... Share this post Link to post Share on other sites
VinsRJ 723 #9 Posted May 24, 2011 As they say, if it fits, it fits! Nice work Bill. :hide: Share this post Link to post Share on other sites
stevasaurus 23,456 #10 Posted May 24, 2011 Very cool Bill...nice to bring the work off the ground and up to a comfortable height. :hide: Share this post Link to post Share on other sites
312Hydro 474 #11 Posted May 25, 2011 Great setup. Reminds me of those fishing pictures where they show off their record catch! :hide: Share this post Link to post Share on other sites
chris11 184 #12 Posted May 25, 2011 Well it will work good for changing the oil. :hide: Share this post Link to post Share on other sites
horsefeathers 15 #13 Posted May 25, 2011 Wild Bill, Was the horse runnin' when you lynched it? I'll bet it ran outa' gas before it kicked the rod from oil starvation! That's great "redneck tech" Hangem' High! HORSEFEATHERS! Share this post Link to post Share on other sites
JC 1965 1,532 #14 Posted May 25, 2011 :WRS: Nice idea Bill, One thing for sure, you shouldn't have any trouble getting to all the parts to work on them. You can just turn it any direction you want. :hide: Share this post Link to post Share on other sites
chesbaycruiser 83 #15 Posted May 26, 2011 Excellent job "neighbor"! :hide: Share this post Link to post Share on other sites
