coreysomerville 0 #1 Posted May 23, 2011 Anyone in South East WI. want to get my 520h running? I plowed with it all winter and parked it after the groundhogs day storm and now it won't start. The engine has compression,fuel, and spark. I've check all the wires to the relay's and believe all that are suppost to have juice do. The grass is now 12" tall and I can't figure out the issue. I'm willing to pay cash. I just don't want to take it to a dealer and pay the huge amount they charge. I believe it something simple. I just don't see any problems as I am not a mechanic. Thanks. coreysomerville@yahoo.com Share this post Link to post Share on other sites
WH nut 553 #2 Posted May 23, 2011 Try a new set of plugs, and double check the spark and fuel, you are missing something Share this post Link to post Share on other sites
coreysomerville 0 #3 Posted May 27, 2011 I can't believe it! New plugs and she fired right up. Share this post Link to post Share on other sites
WH nut 553 #4 Posted May 28, 2011 I can't believe it! New plugs and she fired right up. :hide: Share this post Link to post Share on other sites
305 380 #5 Posted May 28, 2011 I can't believe it! New plugs and she fired right up. plugs can fire fine when you have them out of the engine , but get some compression on them and they may not spark. i test every plug i install with my AC spark plug tester/cleaner here is a NGK from my motorcycle firing fine at 110 PSI , at 120 the spark went out Share this post Link to post Share on other sites
