coreysomerville
Any mechanic's in South East WI
coreysomerville
Anyone in South East WI. want to get my 520h running? I plowed with it all winter and parked it after the groundhogs day storm and now it won't start. The engine has compression,fuel, and spark. I've check all the wires to the relay's and believe all that are suppost to have juice do. The grass is now 12" tall and I can't figure out the issue. I'm willing to pay cash. I just don't want to take it to a dealer and pay the huge amount they charge. I believe it something simple. I just don't see any problems as I am not a mechanic. Thanks. coreysomerville@yahoo.com
WH nut
Try a new set of plugs, and double check the spark and fuel, you are missing something
coreysomerville
I can't believe it! New plugs and she fired right up.
WH nut
:hide:
plugs can fire fine when you have them out of the engine , but get some compression on them and they may not spark. i test every plug i install with my AC spark plug tester/cleaner
here is a NGK from my motorcycle firing fine at 110 PSI , at 120 the spark went out
