Smokey Blaze 2 #1 Posted May 22, 2011 I was cutting grass with my WH 211-5 and stopped to empty the bags on the grass catcher. After emptying the bags I tried to restart the 211, but it would not turn over. Turned the key and nothing, not even a click. Even the headlights would not come on. After a little tinkering I was able to start the 211 by jumping the terminal posts on the the solenoid. My question is this. Is my problem with the ignition switch or the solenoid? The 211 is equipped with its original B & S 11 hp engine. The battery was new in November, 2010. :hide: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted May 22, 2011 Check the interlock (safety) switches first. (PTO disengaged completely, clutch pedal completely depressed, etc.) If it has any fuses, check them too. Share this post Link to post Share on other sites
rmaynard 16,404 #3 Posted May 22, 2011 When you turn the key to start, does the solenoid click? If so, the switch is okay. Share this post Link to post Share on other sites
Smokey Blaze 2 #4 Posted May 22, 2011 Safety switches all seem ok, Clutch fully depressed, PTO switch off. Share this post Link to post Share on other sites
Smokey Blaze 2 #5 Posted May 22, 2011 Checked fuses. No "clicking noise" when trying to start with the key / ignition switch. I should also add that once I got the 211 started by jumping the terminals on the solenoid I ran the tractor for a while then turned it off with the key. I immediately restarted the engine with the key / ignition switch. After finishing the job and blowing the tractor off I tried to restart it and experienced the same problem. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted May 22, 2011 Disconnect the plug from the ignition switch & plug it in again. Sometimes they "lose contact" at the terminals. Do you have a test light or a "multi-meter"? :hide: Share this post Link to post Share on other sites
Smokey Blaze 2 #7 Posted May 22, 2011 disconnected plug from ignition switch and plugged it back in. It seems secure and in place. I do have a test light Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted May 22, 2011 I sent you a PM. :hide: Share this post Link to post Share on other sites
