LuckyJohn 0 #1 Posted May 22, 2011 When running a new fuel line today I found that one of my bushings were the slot hitch slides into on the gas tank frame has busted, does anybody got the part number or a place were to pick these up at. As always thanks in advance. John Share this post Link to post Share on other sites
C-Series14 15 #2 Posted May 22, 2011 What tractor? If you have the VIN number, it should be able to be looked up....On Toro's site or some of the other parts diagram sites. Share this post Link to post Share on other sites
LuckyJohn 0 #3 Posted May 22, 2011 What tractor? If you have the VIN number, it should be able to be looked up....On Toro's site or some of the other parts diagram sites. OK I feel like a dummy now... It is a C-101, tractor # is 81-10K801-14747. Here is the measurements that i have from the good one OD of the area that goes inside of the frame is 7/8"; OD of the washer part is 1 1/8" and the ID of were the "rock shaft" slides into is 3/4". Share this post Link to post Share on other sites
LuckyJohn 0 #4 Posted May 22, 2011 After doing some research I think this is the part number, let me know if you all think it is correct. Toro part # 6229. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted May 22, 2011 I believe P/N 6254 is the one you want: LINK to IPL for model #85514 hitch. Share this post Link to post Share on other sites
LuckyJohn 0 #6 Posted May 22, 2011 I believe P/N 6254 is the one you want: LINK to IPL for model #85514 hitch. Yeah that looks correct, I wish I could find some measurements on that Part Number before I order. Share this post Link to post Share on other sites
