wh1257 226 #1 Posted May 22, 2011 hello I have a problem with my raider 12 when I turn the key for him to run, then bolt it but when I release the key then is he still I do not recall where it may be who can help me :WRS: Share this post Link to post Share on other sites
catman81056 3 #2 Posted May 22, 2011 Not really sure what you're saying. Share this post Link to post Share on other sites
wh1257 226 #3 Posted May 22, 2011 Not really sure what you're saying. normally start to turn the key and then let him go and he stays running but when I release the key then is he simply stopped :hide: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted May 22, 2011 Sounds like it's time for a new ignition switch. :hide: Share this post Link to post Share on other sites
wh1257 226 #5 Posted May 22, 2011 Sounds like it's time for a new ignition switch. I have replaced it are on an entirely new Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted May 22, 2011 It must not be the correct switch then. Share this post Link to post Share on other sites
rmaynard 16,992 #7 Posted May 22, 2011 Vincent, If you have a multi-meter, check to make sure that you have 12 volts at the (+) side of the coil when you turn the key to ON. When you turn the key to START, the 12 volts should still be there, and when you release the key, you should still have 12 volts at the coil. If you don't, then you either have the switch wired wrong or the new switch is bad. Share this post Link to post Share on other sites
