truckin88 104 #1 Posted May 21, 2011 As some of you know I am looking for a newer motor for my C-120, I seem to have found a Magnum off a WH, will it swap right in place of the K Series? Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted May 21, 2011 It is a bolt in, but you will need to change the ign. switch and do some wiring mods, but if it's off a WH everything else will be a bolt on. This magnum is a single cyl. right?? Share this post Link to post Share on other sites
Cody 277 #3 Posted May 21, 2011 I am pretty sure the hood will have to be cut because the shroud on the magnum is different than on a K series, I have tried it already but didnt go through with it because i didnt want to cut up the hood. Share this post Link to post Share on other sites
truckin88 104 #4 Posted May 21, 2011 Kelly M12 Single Cyl Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted May 23, 2011 He maybe right on the cooling tin, but I think the tin from your old engine will fit on the magnum, but not sure on that with the ign. system, I know the aircleaner housing is bigger but that is a easy swap. Share this post Link to post Share on other sites
