trainman 0 #1 Posted May 18, 2011 I have a question, I own a Wheel Horse 211-5 rider with the 38" deck i have the deck setting at the highest setting but I am still scalping the grass there are no more holes to put the adjuster in I was going to drill another hole but I am asking you people on here first I don't want to mess it up. Will taller deck wheels help this problem? I thought about leaving the deck in the up position and then adjust the deck to a lower setting but not sure if that would work. I bought this unit used. So no manual to help me. Any help from you folks would be great! Share this post Link to post Share on other sites
MikesRJ 563 #2 Posted May 18, 2011 Your deck is probably a 37", not a 38", and model number 35-37SL01. That aside, are you sure the deck is adjusted correctly? It should be level. or just slightly low in the front (no more than 1/8"), when parked on a flat surface? Also, and this is a dumb question but, is it assembled correctly? http://www.partstree.com/parts/dispdiagimg...&ilRO=0&ilSC=40 Share this post Link to post Share on other sites
trainman 0 #3 Posted May 20, 2011 I dropped the deck to replace the deck belt but took photos of it before hand to make sure I put it back on properly. How do you adjust the deck? Share this post Link to post Share on other sites
