cletus 0 #1 Posted May 15, 2011 can anyone point me in the direction of a 5 lug ignition for my charger 12,either new or second hand.the old one was very worn and has now died :hide: Share this post Link to post Share on other sites
Anglo Traction 761 #2 Posted May 15, 2011 Hi Cletus, I may have what you need. However, I would need you to post your Model and Serial nbr of your Charger 12, as I'm not sure if they are the same for the years it was produced. Will need to check part nbrs first. Share this post Link to post Share on other sites
cletus 0 #3 Posted May 16, 2011 just been to check serial numbers etc.. model 1-0400 serial 119550 any help with ignition and the manufacter year greatly received! :hide: Share this post Link to post Share on other sites
Anglo Traction 761 #4 Posted May 16, 2011 Hi Cletus, Your Charger 12 is a 1971. You should have a 4 Position Switch - Off, Run & Acc'ys, Run and Start. The Switch Part nbr is 101917. I have one which is really my Spare for the Raider, it is Used and fully functional and clean. I'll send you a PM. Regards. Share this post Link to post Share on other sites
