Operator 7 #1 Posted May 15, 2011 Get the opinion of others on this. I have a 60" deck that came with my C-195 it is a lighter model than my other 60" and I would like to put it on my 520H. Looking at it it seems higher in the linkage area, C sits higher. I can't swap linkage between the two. Anyone put one on? They are heavy decks and I don't want to unhook and rehook them if it doesn't work Share this post Link to post Share on other sites
Horse Fanatic 51 #2 Posted May 16, 2011 I'm curious about the opposite question, can I use a later 60" deck from a 520H on a C195? Share this post Link to post Share on other sites
Operator 7 #3 Posted May 17, 2011 I'm curious about the opposite question, can I use a later 60" deck from a 520H on a C195? I'm guessing on this one but I bet you could, you would have the clearance but it might not drop down enough. Just a guess though. Share this post Link to post Share on other sites
Nick 13 #4 Posted May 17, 2011 Ive seen the 195 60" deck used on another tractor so I guess it should work OK on the 520. The 520s 60" deck is pretty tall itself, it barely raises on a 520 so Id guess it would work fine on a C-195 also. Share this post Link to post Share on other sites
Operator 7 #5 Posted May 18, 2011 OK Nick , I'll try it without any revamping, first. Share this post Link to post Share on other sites
Nick 13 #6 Posted May 18, 2011 Did some looking and found the picture of that c-195 deck under a 417. Not sure how well it worked cant rememebr what the owner said at the time. http://www.wheelhorseforum.com/index.php?...760&hl=195+deck Share this post Link to post Share on other sites
