zach l 2 #1 Posted May 12, 2011 i have a hh100 and its not getting any spark any ideas? Share this post Link to post Share on other sites
Save Old Iron 1,571 #2 Posted May 13, 2011 Zach, if this is what your system looks like lift the wire (yellow in pic) to the external SSI module and lift the kill wire from the ignition switch use a multimeter on AC volts (range setting will be for approximately 100 volts) clip one lead to the open end of the yellow wire - the other lead to ground crank the engine depending on the multimeter - you should see anywhere fro 60 to 100+ volts AC on the display voltage here would confirm the charge coil in the stator is probably OK no voltage = stator charge coil is bad / bad ground connection from stator to engine / kill wire is grounded 60 - 100 VAC reading = probably defective SSI unit. Check the back of the SSI unit for burn marks. ///////////////////////////////////////////////////////////////////////// before you disconnect the multimeter from the charge wire to the SSI unit, you could also measure the resistance of the charge coil to ground approximately 400 ohms = good much less than 400 ohms = short to ground infinite or over range resistance = open wiring in the charge coil (bad stator assy) let us know Share this post Link to post Share on other sites
Save Old Iron 1,571 #3 Posted May 13, 2011 another thread that might be of some interest http://www.wheelhorseforum.com/index.php?...topic=27961&hl= Share this post Link to post Share on other sites
Save Old Iron 1,571 #4 Posted May 13, 2011 sorry - double post Share this post Link to post Share on other sites
