sscotsman 194 #1 Posted May 11, 2011 So I took the 854 out this evening to do some chores, and ran into a bit of a problem! I recently installed the mower deck: My neighbor across the street told me about some old wood fence pieces he had, that were laying out in the field behind his property, and he said my wife and I could have them! (we are going to use the old round stringers for garden bed edging)..good use for the tractor and cart! So I hook up the cart..since im going to drive the tractor way out in the back fields, I wanted to raise up the mowing deck, just so it wasnt running along the ground...problem though! When I use the lift lever to raise up the deck, it ALSO raises up the rear hitch! which basically means I cant run the tractor with the deck raised *and* the cart attached..to use the cart, the deck has to be lowered.. not a huge deal really..I just ran the tractor with the mowing deck down, not running, and it was fine..but for future use, I would like to be able to raise the deck *and* use the cart at the same time..here is a photo of the hitch: So about an hour after putting the tractor back in the garage for the night, im reading new posts here on redsquare, and check out what I see! http://www.wheelhorseforum.com/index.php?...topic=28096&hl= Take a look at the rear hitch on Chas' 854..thats exactly what I need! TWO hitches! one that raises and lowers with the lift lever, and one that doesn't.. Where can I find a hitch like this? would Tractor Supply carry something like that? and how do I remove the current hitch to slide in that new hinge pin? there is nothing visible to "unscrew"..does it have to be pushed/pressed out? thanks, Scot Share this post Link to post Share on other sites
can whlvr 994 #2 Posted May 11, 2011 thats all factory hitches on that tractor,the lower hitch was on most wheelhorses,not sure for your tractor but any that i have came with the standard hitch,you can get that from some members here that part out tractors,i would post in the want adds or some one will chime in,and you have the second hitch all ready,it fits in place of the spacers that are used on the standard hitch Share this post Link to post Share on other sites
daveoman1966 3,880 #3 Posted May 11, 2011 This is the combination hitch you are looking for. For more pics and further details, EXIT RED SQ and send me an email.... I'll reply with pics and price for you... shipped. my email is: daveoman@windstream.net Attached Image Share this post Link to post Share on other sites
Don1977 605 #4 Posted May 11, 2011 All you needed to do was disconnect the lift cable from the rear hitch. You would have to tie the hitch up level, just a temporary fix. Share this post Link to post Share on other sites
wheelhorse656 20 #5 Posted May 11, 2011 i just made a strait bracket to hold the hitch while i had my snow blade on. it worked really good i can get you a few pics if you want. :hide: Share this post Link to post Share on other sites
c175inMA 8 #6 Posted May 11, 2011 There are several hitches on ebay right now with the pin that holds them to the transmission. your pin looks like it was cut. There should be a snap-ring at the end of the pin. if your pin isn't frozen it should come out easily Share this post Link to post Share on other sites
Kelly 1,033 #7 Posted May 12, 2011 Yup just add a factory fixed hitch, you will need a longer pin, but i use a farm hitch pin from TSC, I have fixed hitches also,if you need one. 1 Share this post Link to post Share on other sites
sscotsman 194 #8 Posted May 12, 2011 Thanks for the ideas everyone! i just made a strait bracket to hold the hitch while i had my snow blade on. it worked really good i can get you a few pics if you want yes, would love to see a photo please! There are several hitches on ebay right now with the pin that holds them to the transmission. your pin looks like it was cut. There should be a snap-ring at the end of the pin. if your pin isn't frozen it should come out easily what was cut on mine? not sure what the "cut pin" is that you are referring to.. Yup just add a factory fixed hitch, you will need a longer pin, but i use a farm hitch pin from TSC, I have fixed hitches also,if you need one. anyone have a photo of a "factory fixed hitch" they could post? thanks! Scot Share this post Link to post Share on other sites
Save Old Iron 1,571 #9 Posted May 12, 2011 looks like its been covered here Share this post Link to post Share on other sites
sscotsman 194 #10 Posted May 12, 2011 just temporarily remove this pin and the rear hitch will not be able to be lifted ! thanks! I tried that! but that doesnt work..because the hitch has to be supported by *something*..if I just remove the pin, the hitch sags down to the ground..and because I have a 2-wheel cart, I get this: the hitch is the only thing holding up the cart.. I think for now I will just rig up a temorary fix: (awesome artwork huh? ) Scot 1 Share this post Link to post Share on other sites
Martin 2,133 #11 Posted May 12, 2011 scot. heres a pic of the fixed hitch with its longer pin. the spacers on the longer pin are used if the fixed hitch is mounted by itself .... or you mount them as an assembly, in that case use the longer pin without the spacers. heres what you have now with the shorter pin.... hope this clears it up for you abit... Share this post Link to post Share on other sites
sscotsman 194 #12 Posted May 12, 2011 Thanks Martin! (and now I understand the "cut pin" reference too.) I will look around for something like that! thanks, Scot Share this post Link to post Share on other sites
AEarlCheal 1 #13 Posted July 24, 2012 How do you remove the pin to remove the rear hitch? Share this post Link to post Share on other sites
JUSS10 250 #14 Posted July 26, 2012 there are snap rings on either side that you remove. however, removing those rings are usually the least of the issues. The pin is usually seized to the transmission housing or lift hitch its self. if thats the case, i usually find it easiest to just cut the pin between the transmission and the hitch on both sides, remove the hitch and pound the pins out, then carefully pound the pin out of the transmission housing. All you need then is a 3/4 farm hitch pin or a even a bolt with a long enough shaft will work, make sure to grease it or put some never seize on it. hope that helps 1 Share this post Link to post Share on other sites
AEarlCheal 1 #15 Posted July 26, 2012 Thanks. Snap rings are gone. Pin is frozen. Have penetrating oil on now. Will also try heat, then pound it out. Share this post Link to post Share on other sites
KC9KAS 4,744 #16 Posted July 26, 2012 Use a punch on the pin...If you hit directly on the pin, it will mushroom and you will never get it out! Keep putting a penetrating fluid on it and let it set.....drive the pin 1 direction, then the other direction, spraying more penetrant on the newly exposed part of the pin. I just removed one a few weeks ago. Mine was already mushroomed, so I had to use an angle grinder to remove the mashed ends. It takes a little time and patients....you don't want to break anything! 1 Share this post Link to post Share on other sites
