HorseFixer 2,013 #1 Posted May 9, 2011 I started working on a 417A. I noticed alot of play in the steering wheel shaft, mainly in the dash tower. Whats a good way to fix, modify this to tighten it up? A thicker metal back up plate with a bearing? What have you guys done? Thanks ~Duke Share this post Link to post Share on other sites
Gene_S 93 #2 Posted May 9, 2011 Duke is the upper bushing just worn out? My 416-8 was the same way and I replaced the upper bushing and fixed the problem. I had to remove the steering wheel and split the upper dash from the lower dash. If you look just behind the battery you'll see the bushing. If you need one I have 4 or 5 extra new ones. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted May 9, 2011 Take a look at this thread Duke. Some idea's on how to fix it and some photo's of what I did on my 520H: Share this post Link to post Share on other sites
stevasaurus 23,521 #4 Posted May 9, 2011 How ya doing Bob...we going to see some pictures of this horse?? :hide: Share this post Link to post Share on other sites
Don1977 605 #5 Posted May 9, 2011 Duke, I've see your work, go ahead and reinforce it with a good bearing or oilite bushing. I don't have one of those tractors but from what I see it's not a very good design. Share this post Link to post Share on other sites
HorseFixer 2,013 #6 Posted May 9, 2011 Thanks Geno I was wondering if it might need some stiffer metal also? I will look closer at the bushing tonight. Mike: I cant see the pictures from work cause they block them? So I will look when I get home The bearing thing does seem like a heavy duty repair And since I over do things anyways that my be more down my alley! Steve: Im doing okay, been busy around the house, putting in a sprinkler system, yard work, cleaning garage and look to be thinning the WH herd a bit So's I can have more room as The Duke "O" Minium stable is busting at the gills. The stuff that prolly will be going..... I have a RJ55 (3) 58's << 1 restoreable 2 for parts a 551, << W/ a missing Starter a 701 rolling chasis, a 854 << W hacked hood, a 702 << W locked up rear end a RR-832 << (Ole Smokey) but runs good an RR-65 (I think) << The Bathtub . I plan on getting the herd down to a manageable 12 with 10 in the stable and the C120 abd 417A in the garage. Anyways I dont have to tell you for us city dwellers thats enough to store & to keep running! And as far as the pics of the 417 goes, she looks a little better in the 1st picture than she really is. Here is the link. Don: Im gonna take a closer look tonight and see how hard it will be to get that steering wheel off. From reading Mikes thread that might be getting myself in a pickle and me dont like pickles! Oh and that plastic cover on the steering shaft what kinda deal is that???? 417A Repair Take Care! ~Duke Share this post Link to post Share on other sites
can whlvr 994 #7 Posted May 10, 2011 just read this post and i got another 414,50 dollar special,coulnt get the wheel off of it either,the thick iron plate cut to fit the shaft in 2 peices works great,si i had to drill a few holes,thats a small price to pay for nice tight steering shaft. Share this post Link to post Share on other sites
HorseFixer 2,013 #8 Posted May 10, 2011 Mike looked at the pictures and thats a nice job ya did right there. I was easily able to get the steering wheel off so looks like I'm on my way. I like the bearing Idea but also Like Canada Don's plate stiffening idea also. I'm taking the Ole bushing & plate into work and stop by bearing services tomorrow and get some Ideas on types of bearings. Thanks to all. ~Duke Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted May 10, 2011 I've never seen a 417, so now I see it's quite different from the 520 setup. Howabout just bolting one of the flanged bearings that Wheel Horse used on the front of the lower steering shaft onto the flange on your dash panel? (The thingy sitting on the chassis rail in this pic:) They cost about $8 at your local friendly Toro dealer. Share this post Link to post Share on other sites
HorseFixer 2,013 #10 Posted May 10, 2011 Dog Gone U Mike you stole my thunder Yep was gonna suprise you guys, thats exactly what I had in mind. I have used alot of different bearings in the HVAC industry on blowers and things. I think I will also maybe stiffen that area with a strip of some 1/16" stainless steel. Well I will ck my bearing place if they dont have it will do toro. You wouldnt happen to have a part # would you? cant do toro master parts viewer from work Damn County thinks employees are gonna infiltrate their puker system Thanks again ~Duke Share this post Link to post Share on other sites
sorekiwi 761 #11 Posted May 10, 2011 You wouldnt happen to have a part # would you? Sorry Duke! #6472 (Bearing - Flanged) Share this post Link to post Share on other sites
HorseFixer 2,013 #12 Posted May 10, 2011 You wouldnt happen to have a part # would you? Sorry Duke! #6472 (Bearing - Flanged) Thanks Bro thats a big help! I gotta get one of those and a tranny filter. ~Duke Share this post Link to post Share on other sites
truckin88 104 #13 Posted May 10, 2011 Duke, Stevebo had a 416-8 that the PO had a custom solid steering shaft machined, because he didn't like the play in the wheel, it was pretty trick. Maybe Stevebo or whomever owns the tractor now can comment... Share this post Link to post Share on other sites
HorseFixer 2,013 #14 Posted May 10, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Share this post Link to post Share on other sites
Butch 194 #15 Posted May 10, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Govenors cut?? Isn't that so they can pay you to surf the web from work? Hmmmmm?? Share this post Link to post Share on other sites
JimD 3,347 #16 Posted May 10, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Govenors cut?? Isn't that so they can pay you to surf the web from work? Hmmmmm?? :) Share this post Link to post Share on other sites
HorseFixer 2,013 #18 Posted May 11, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Govenors cut?? Isn't that so they can pay you to surf the web from work? Hmmmmm?? Nope! thats to pay for Air Traffic Controllers To Take A Nap! Another Air Traffic Controller Falls Asleep On Job by The Associated Press April 16, 2011 The government is changing air traffic controllers' work schedules most likely to cause fatigue following another incident in which a controller fell asleep while on duty, this time at a radar center in Miami, the Federal Aviation Administration said Saturday. The latest sleeping incident Share this post Link to post Share on other sites
Butch 194 #19 Posted May 11, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Govenors cut?? Isn't that so they can pay you to surf the web from work? Hmmmmm?? Nope! thats to pay for Air Traffic Controllers To Take A Nap! You're confusing "governor" with "uncle sam"!!! The governor is for you. Sam WAS for me. It's only 2:30. You can do a web search and check to see if I'm right!! :disgust: Share this post Link to post Share on other sites
HorseFixer 2,013 #20 Posted May 13, 2011 Update: Just ordered thru Dealer have tomorrow $9.81 plus the govenors cut. ~Duke Govenors cut?? Isn't that so they can pay you to surf the web from work? Hmmmmm?? Nope! thats to pay for Air Traffic Controllers To Take A Nap! You're confusing "governor" with "uncle sam"!!! The governor is for you. Sam WAS for me. It's only 2:30. You can do a web search and check to see if I'm right!! Well that only took a day to answer back, you musta took an extra long nap just like in the ole days huh? :) Share this post Link to post Share on other sites
truckin88 104 #21 Posted May 21, 2011 Duke, you ever fix this my 314 is having the same issue.... I'd like to see the fix Share this post Link to post Share on other sites
