KyBlue 655 #1 Posted May 26, 2008 Since Toro has let me down for the manuals, I'll post the couple ?'s that I have here for all the great WH minds to answer! I need to change the Rear End Lube on my B80, what should it get refilled with, and how much? Also where is the drain plug? And you refill thru the dipstick hole right? Finally, Since the Lube in the axle looks like total :wtf: and the overall condition of the deck, and the rest of the tractor, Im going to say that it REALLY needs greased. Where are the grease Points? I figure that'll do it for now .. Share this post Link to post Share on other sites
catman81056 3 #2 Posted May 26, 2008 If I can do this right, try here. http://f1.grp.yahoofs.com/v1/8EA7SEAJy4lK5...0Capacities.pdf The drain plug should be towards the rear left side of the trany and possibly next to the hitch. Try here also. http://f1.grp.yahoofs.com/v1/AE87SFQU-8XUV...0C%20Models.pdf Share this post Link to post Share on other sites
Confused99 2 #3 Posted May 27, 2008 Not to get off topic but could someone post a link to a manual for my Raider 12? I have tried to find one without any luck. Thanks in advance, Jason Share this post Link to post Share on other sites
WheelHorse_of_course 100 #4 Posted May 27, 2008 Jason, since the Raider was made several years you need to post you vehcile number form the tag under the dash. Share this post Link to post Share on other sites
Confused99 2 #5 Posted May 27, 2008 Jason, since the Raider was made several years you need to post you vehcile number form the tag under the dash. It is 1 6251 and the serial number is 662874. Thanks, Jason Share this post Link to post Share on other sites
KyBlue 655 #6 Posted May 27, 2008 neither of the links work. Thats my kinda luck right there.. :whistle: Share this post Link to post Share on other sites
linen beige 16 #7 Posted May 27, 2008 I need to change the Rear End Lube on my B80, what should it get refilled with, and how much? Also where is the drain plug? And you refill thru the dipstick hole right? Scott, My lube recomendations and usage chart shows 2 qt.s of SAE 90-140 A.P.I. service GL-5 gear lube, with no service inteval recomendations. I think someone else has you covered on the drain plug location. If the lube that's in it really looks BAD, I'd flush it out REALLY well before I used it much. Or better yet, open it up, wash it out, and replace any seals, etc. it might need. Share this post Link to post Share on other sites
catman81056 3 #8 Posted May 27, 2008 Scott I can try to send you a copy of the owners manuel for your tractor. The file size is 1.44megs. Let me know if you want it. Well it covers;B-60,80,100 w/8spd C-120 and C-160 w/8spd and auto Share this post Link to post Share on other sites
KyBlue 655 #9 Posted May 28, 2008 Yeah Tim, Id love to have a copy ... Thanks! Thanks Jim, it'll get changed now, and run for a bit, and then changed again after a couple weeks use. Share this post Link to post Share on other sites
CasualObserver 3,414 #10 Posted May 28, 2008 Scott...just a suggestion here... go back and take out your email address and then PM it to Tim.... you don't want to post things like that out in the searchable board text. (even in that form) The forums are prime pickings for spy/spambots. Share this post Link to post Share on other sites
KyBlue 655 #11 Posted May 28, 2008 Thanks for the heads up Jason - He got me the Manual this morning, Thanks a Ton Tim!! Share this post Link to post Share on other sites
catman81056 3 #12 Posted May 28, 2008 No prob Scott I was just hoping it went thru!! Share this post Link to post Share on other sites
