WH Raider10 17 #1 Posted May 4, 2011 Hi, Yesterday I got my drive belt for my tiller in the mail. Hooked the tiller up onto the 312-8 and started with some testing on my tilling skills. I've found out that the tiller sometimes stops turning because the ground is to hard. Is this normal,does it have some sort of safety/clutch inside of the gearbox??? I also have a problem with my height settings. Can somebody give his opinion on his settings on the chain to raise the tiller? Sometimes I've have to raise or hold the lifting arm in position so it won't stop turning in the ground. How much tension do I need to put on the big lifting spring? Thanks, Pieter-Jan :thumbs: Share this post Link to post Share on other sites
pfrederi 19,936 #2 Posted May 4, 2011 There is no slip capability in the tiller itself. Either your belt is slipping or more likely your PTO clutch needs adjustment. 1 Share this post Link to post Share on other sites
