LuckyJohn 0 #1 Posted April 29, 2011 I am just curious what is needed, I have the oil filter size and what type of oil is recommended for the engine but what about the rearend, what type of oil and filter is required and does anybody have the part number for the air filter and spark plugs? Thanks in advance as usual. John Share this post Link to post Share on other sites
Cody 283 #2 Posted April 30, 2011 The rear end uses 10w30 engine oil and the filter is toro # 108335 or i use the stens filter which is # 120-265. For the spark plugs use NGK's BKR5E plugs. The air filter is toro # NN10774 onan #140-1228/140-2522/140-2628-01 or stens # 100-149 & pre filter # 100-875. Hope this helps Share this post Link to post Share on other sites
LuckyJohn 0 #3 Posted April 30, 2011 The rear end uses 10w30 engine oil and the filter is toro # 108335 or i use the stens filter which is # 120-265. For the spark plugs use NGK's BKR5E plugs. The air filter is toro # NN10774 onan #140-1228/140-2522/140-2628-01 or stens # 100-149 & pre filter # 100-875. Hope this helps Wow, the rear end uses 10W-30 Engine oil? That is unique isn't it. Is there a place on the web that I can purchase these products from by using the parts numbers listed? Share this post Link to post Share on other sites
Cody 283 #4 Posted April 30, 2011 Yes the rear end uses 10w30 engine oil, you should be able to order all the parts needed from http://www.jackssmallengines.com/ if you want to order them from the internet. If you use jacksmallengines use the toro numbers i gave you for the parts. Share this post Link to post Share on other sites
