jachady 130 #1 Posted April 29, 2011 I've got a 314-A, will it have enough power to spin up a 48" deck? I tried the search but couldn't fin an answer. Any help would be great. John Share this post Link to post Share on other sites
Duff 206 #2 Posted April 29, 2011 John, I think I did see this discussed somewhere else but I'm not sure what search words would narrow it down. Anyway, if memory serves me the answer to your question should be yes...as long as you keep your blades sharp, watch your forward speed and don't try to mow grass that's too tall. Duff :thumbs: Share this post Link to post Share on other sites
WH854 45 #3 Posted April 29, 2011 John put your tractor model# here I used (21-14KE01) Toro says it will fit https://homeownersolutions.toro.com/portal/...ductDetailsPage Chas Share this post Link to post Share on other sites
btrrg1969 11 #4 Posted April 29, 2011 I have a 48" on my 312 and my buddy has one on his 310 :thumbs: Share this post Link to post Share on other sites
danjmah 74 #5 Posted May 2, 2011 I have an 88' 414-8 with a 48" SD deck and it cuts and performs beautifully. I haven't noticed any issues. Share this post Link to post Share on other sites
shorts 182 #6 Posted May 3, 2011 I have an early 70's 12 hp commercial toro that spins a 3 blade 60"deck and pulls me around on a sulky without bogging down unless I go into bushhog mode, keep the blades sharp and engine speed at wide open and go slow enough that the clippings don't clog up in the deck. :thumbs: Share this post Link to post Share on other sites
tarcoleo 120 #7 Posted May 12, 2011 Your Kohler 14 hp is enough; I run a 48" SD deck with a Honda 11 hp or a 13 hp, on level ground, with no problems. Tom in RI Share this post Link to post Share on other sites
bo dawg 565 #8 Posted May 15, 2011 No problem for it! Share this post Link to post Share on other sites
tommy3horse 3 #9 Posted May 15, 2011 I run both a Charger 12 and a C-120 with a 48 inch decks and both do very well with no "power" issues. My 3 acres are NOT flat at all either. Tom :hide: Share this post Link to post Share on other sites
jachady 130 #10 Posted May 25, 2011 Ok, so it doesn't seem like power is an issue. But I've hooked up the mower and the blades are still slowing down. So I've come up with possible issues. Just need help determining which one to attack first. My thoughts are that A) the blades aren't sharp or tight, the deck belt is bad or the spring is shot, C) the pto belt is shot (I'm running it in the inner pulley on the pto), or D) the pto clutch material is worn. Of course there could be E) letting the grass get too long before mowing (but it doesn't seem like the engine is bogging down) It doesn't cost anything to make sure the blades are sharp and tight, so I'll do that. But before I buy anything, any tips on how to check for a bad belt or pto? Thanks John Share this post Link to post Share on other sites
can whlvr 994 #11 Posted May 26, 2011 it also doesnt cost to take your pto off and inspect and clean,look for oil or grease on the disk,if there is none clean it and scuff it up a little,take notice where the trunnion is before you take it apart,so you can tighten it a little,they do need to be adjusted from time to time,also make sure the pulley on the deck is tight,if its slipping that will slow the blades,a new set of belts might be a good investment too but only if you dont find the problem,good luck Share this post Link to post Share on other sites
shorts 182 #12 Posted May 26, 2011 when inspecting the belts and pulleys look closely at the v grooves in the pulleys for wear, the sides of the v's should be straight from the outside dia to the bottom of the groove and the belts should be 5/8'' wide and seat into the outer part of the v and not down in the bottom of the pulley :hide: Share this post Link to post Share on other sites
jachady 130 #13 Posted June 8, 2011 So, my non-mechanically inclined brother figured this one out. The PTO lever was out of adjustment. When we pushed the lever all the way forward the PTO actually slightly released. If we just push the lever about 90% forward the PTO is tight and spinning at full speed. So a little adjustment to the trunion on the PTO rod and we're back in business. John Share this post Link to post Share on other sites
