case442 132 #1 Posted April 26, 2011 Hi All, I have a NOS clevis hitch that i'm considering putting on my 312-8 or C-101. Does anyone have an installation diagram for my install? Thank you, Mike (case442) Share this post Link to post Share on other sites
racinfool40 203 #2 Posted April 26, 2011 Not sure exactly what style you have?? Might try this one: http://www.mywheelhorse.com/graphics/file/...18_810834RB.pdf Share this post Link to post Share on other sites
Butch 194 #3 Posted April 26, 2011 What are the differences between the Type A and Type B? Can they both be used on the same tractors? Thanks. Share this post Link to post Share on other sites
racinfool40 203 #4 Posted April 26, 2011 HMMM Good question Butch!! Here's the other manual I found.. Not much different except for the rocker shaft.. this one mounts straight to the lift cable!! http://www.mywheelhorse.com/graphics/file/...5511_803916.pdf Share this post Link to post Share on other sites
case442 132 #5 Posted April 27, 2011 Thank you Guys, I think my is type A, but its definately older. I will look at it tommorrow. Thank you, Mike Share this post Link to post Share on other sites
daveoman1966 3,841 #6 Posted April 27, 2011 This is a clevis hitch on my 414-8. The Slot hitch would hoop up the same way. pf... I awlays use a BigAzz 'D' ring pull pin instead of the original pin with the circlips. Makes it much easier and faster to swap out hitches. Attached Image Share this post Link to post Share on other sites
daveoman1966 3,841 #7 Posted April 27, 2011 Here is a 2nd pic of the clevis hitch hookup. Attached Image Share this post Link to post Share on other sites
tgranthamfd 29 #8 Posted May 1, 2011 Not sure exactly what style you have?? Might try this one: http://www.mywheelhorse.com/graphics/file/...18_810834RB.pdf This should be the one you need for the 312-8 or the C-101. That is the manual I put on there after I bought a kit and put it on My 2005 Toro Wheel Horse 315-8 Classic GT. I also put my own pictures on here because some in the manual wasn't very close or clear. Only difference I could see from the links, was 1 looked to be for older C series (pre 78) and this link should be for 78 and newer. for sure though. Share this post Link to post Share on other sites
