ricksrj58 273 #1 Posted April 26, 2011 well this one was interesting since the base of the engine was too wide for the frame and i do not have a welder . so i had to make a temporary halfa@@ed motor mount. Share this post Link to post Share on other sites
hcminis 1,783 #2 Posted April 26, 2011 atta-boy. Looks good. Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted April 26, 2011 That is a WH engine it should have bolt holes in the bottom of the oil pan on the right side from setting on the seat, and they should line up with holes in the frame. Share this post Link to post Share on other sites
bo dawg 640 #4 Posted April 27, 2011 I believe on that one the engine/oilpan base is wider then the frame. I had 2 of them like that. It was only bolted down with the 2 bolts on the left side, sitting in the seat. I've seen quite a few like that. Doesn't seem to hurt anything though. First one I ever owned came that way and I just made a hook bracket that was studded to hook on frame and then through the mounting hole on pan and tightened it down. Share this post Link to post Share on other sites
refracman 167 #5 Posted April 27, 2011 there should be holes in the underside of the pan to bolt it down :thumbs: Share this post Link to post Share on other sites
bo dawg 640 #7 Posted April 27, 2011 Wow, never knew that. But haven't had that many off the frame before either. Share this post Link to post Share on other sites
Kelly 1,038 #8 Posted April 27, 2011 THAT is what I said, but with out the cool pictures with arrows Share this post Link to post Share on other sites
ricksrj58 273 #9 Posted April 27, 2011 i did not know there were extra holes,i never looked at the bottom of the engine lol Share this post Link to post Share on other sites
ricksrj58 273 #10 Posted April 27, 2011 there are threaded holes in the bottom of the pan and yes they ligned up. thank you guys for your superior knowledge :thumbs: Share this post Link to post Share on other sites
