rockinhorse 45 #1 Posted April 23, 2011 Back again i have a C-121 with hydrostatic transmision. Igot the seals changed today,drilled second setscrew holes in hubs. Drained oil out only got about 3 1/2 qts out. Here is my problem specs. say it holds 5 to 5 1/2 qts. I put new filter on to . Put plug back in put oil in (5 qts) now oil dip stick shows oil 1inch above the full mark on dipstick. This is after running tractor. IS there another drain plug some where???? that i have missed?? I drove tractor it drive's ok. I tried looking at manuals on here but could not see anything showing how to change oil. If anybody knows what i"m doing wrong please let me know. thanks again karl flat rock,in tractor is 1978 c-121 81-12KSO1-20099 8152 Share this post Link to post Share on other sites
gwgdog66 23 #2 Posted April 23, 2011 My Brothers Auto, only held 4 1/2 qts. his manual called for 5 also. Share this post Link to post Share on other sites
illinilefttackle 399 #3 Posted April 24, 2011 Karl- I'm not a wheel horse expert-and I didn't play one on TV-but-a good rule to follow in servicing something with fluid in it, is to put back in what you took out-then run it and then check the level again filling as needed. I do remember reading that Eaton doesn;t recommend running their units overfull. I dont know if you have an Eaton or a Sunstrand-but the warning may go for both -Hope everything works out. Al Share this post Link to post Share on other sites
Martin 2,133 #4 Posted April 24, 2011 changed mine today in the 875. 4 quarts in the manual. 4 quarts to full on the stick. with filter. sunstrand hydro. Share this post Link to post Share on other sites
daveoman1966 3,841 #5 Posted April 24, 2011 If Sundstrand, there is a drain plug on the bottom of the left side case. You should NOT run the trans with oil level above the full mark. If you do, there is a propensity of the oil turning to foam. Oil with tiny air bubbles in it will not develop or hold pressure very well. Moreover, precision internal parts may suffer damage from foamy oil...not unlike contaminated oil. You MAY have to let the tractor set for a couple days for the oil to clear itself of foam. OR... drain and refill. This time, fill it to within a margin lower than full, then gradually fill to full mark. This is true for any hydraulic system...Sundstrand or Eaton. Hold true for automatics in cars and trucks too. That's why the dipstick is marked "Do Not Overfill". Attached Image Share this post Link to post Share on other sites
SAM58 30 #6 Posted April 24, 2011 This is true for any hydraulic system...Sundstrand or Eaton. Hold true for automatics in cars and trucks too. That's why the dipstick is marked "Do Not Overfill". Good advise Dave :wh: Share this post Link to post Share on other sites
rockinhorse 45 #7 Posted April 24, 2011 This is true for any hydraulic system...Sundstrand or Eaton. Share this post Link to post Share on other sites
smoreau 658 #9 Posted April 24, 2011 This is true for any hydraulic system...Sundstrand or Eaton. Share this post Link to post Share on other sites
rockinhorse 45 #10 Posted April 24, 2011 This is true for any hydraulic system...Sundstrand or Eaton. Share this post Link to post Share on other sites
