420lse 18 #1 Posted April 21, 2011 Hey guys A little help needed. All the numbers have been painted over. But it has a 16 hp onan w/hydro, and all the controls are on the column,nothing between the legs ,fancy lights on the dash. This guy says it's a 516H. Older units I can figure out. This one has me scratrching me head. Nothing on the the hood ect. Best guesses welcome.True knowlege ,,,priceless :thumbs: Share this post Link to post Share on other sites
zieg72 209 #2 Posted April 21, 2011 It is a 416H, 516H would have had the hydro lever between your legs. Column controls started in the early 90's and 516H were mid to later 80's... Share this post Link to post Share on other sites
rmaynard 16,869 #3 Posted April 21, 2011 :thumbs: Post a couple. As they say, a pictures is worth 1000 words. Share this post Link to post Share on other sites
420lse 18 #4 Posted April 21, 2011 Best I could do. Are these good bad or ugly ? Up side down side ? Share this post Link to post Share on other sites
wh5208speed 669 #5 Posted April 22, 2011 There are several differences between the 516 and 416. The main difference is the 416-H has hydraulic lift and the 516H has a manual lift. The 416-H has the Eaton 1100 which is the better hydro and the 516 runs the Eaton 700....which will tell you in the owners manual to no run ground engauging equipment (mold board plow, disc, culitvator, ect). I have seen a much higher % if eaton 700 go out vs the 1100 (which is a very good tranny ). The 516-H has a gas gauge on the dash....the 416H does not. In the end....in my mind the 416H is a much better tractor than the 516H unless you want to just mow the grass. Thad (Ohio) Share this post Link to post Share on other sites
wh5208speed 669 #6 Posted April 22, 2011 .....Also, if the controls are on the steering colum....it has to be a 416-H. The 516H was made in 1988-89 and those years all of the controls for the hydros were between the legs.....the moved the controls to the steering column in mid -1990 models. Thad (Ohio) Share this post Link to post Share on other sites
lincolnpower38 0 #7 Posted April 22, 2011 416-H. I love mine I put a snow blower and cab on mine and does a geat job! Share this post Link to post Share on other sites
