IthacaJeff 151 #1 Posted April 21, 2011 WH'ers Puttin' the mower deck on the other day and lo' and behold, there it was. A crack in the transmission mounting plate on my 416-8. Lower left side (looking FRONT to BACK) plate has a 1.5" crack radiating from left to right. I don't know how long its been there, heck, perhaps when I bought the thing a couple of years ago. Sorry, don't have a picture, but will get one if necessary. Here are my questions. 1. How do I fix it, particularly without having to dismantle the entire tractor? (Is this possible?) 2. How do I fix it "temporarily" to stop any further damage, but I can do without a welder or taking much down time on my only mower? 3. What should I NOT do to make the problem worse? I'm assuming no heavy pulling, no attachments to the rear axle attach-a-matic. Anything else? Thoughts? Jeff in Enfield, NY Share this post Link to post Share on other sites
SAM58 33 #2 Posted April 21, 2011 :thumbs: would be nice to see it... Share this post Link to post Share on other sites
rmaynard 16,701 #3 Posted April 21, 2011 Had the same problem. Common on these tractors. I had a piece of 1/4" steel cut, drilled, and welded to the plate. Share this post Link to post Share on other sites
IthacaJeff 151 #4 Posted April 21, 2011 Bob, Your solution looks, of course, to be the proper way to fix the problem. Any solution NOT requiring stripping down to the chassis? Jeff Share this post Link to post Share on other sites
B-8074 20 #5 Posted April 21, 2011 Can you post a pic of the crack? Share this post Link to post Share on other sites
rmaynard 16,701 #6 Posted April 21, 2011 Bob, Your solution looks, of course, to be the proper way to fix the problem. Any solution NOT requiring stripping down to the chassis? Jeff You could remove one bolt at a time and insert some big-a$$ washers. If you look at the inside of the plate, it is probably already reinforced with two bars welded on at the factory. All you want to do is prevent the bolt heads from pulling through, so some big thick washers will probably help until such time as you could add the plate. Share this post Link to post Share on other sites
squonk 44,941 #7 Posted April 21, 2011 If you don't want to stack washers, McMaster-Carr has some super-whoopie extra thick washers. Share this post Link to post Share on other sites
Anglo Traction 761 #8 Posted April 21, 2011 Jeff, We need a picture!, One thing to note, if your packing with thick Washers, don't forget to obtain new longer bolts. I think they are Grade 5 in U.S standards. Many tractors use longer ones in the bottom than the top. Either way, increase the bolt length by the extra Washer thickness to ensure adequate thread engagement into the Cast Iron Tranny. I would still look to get the crack welded though. Share this post Link to post Share on other sites
fabricator2009 48 #9 Posted April 21, 2011 Depending on where the crack is, you can drill a 1/16" hole on each end of the crack to keep it from getting worse. Share this post Link to post Share on other sites
