rocko_brown 0 #1 Posted April 21, 2011 ok so im redoing all the wiring on my 1075 but i couldnt find the same gauge wire for the battery ignition wire and ground wire. its a size bigger than stock i believe 6g. will this make a difference in how it performs or will ot damage the electrical at all?? And if so then what is the correct size that i should be using? Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted April 21, 2011 You must be talking about the batt. cables, yes 6G will be fine, I think with out looking I used 4G on the last one I did but I had it in stock. Share this post Link to post Share on other sites
