case442 132 #1 Posted April 21, 2011 Hi All, Will a 48" snow blade mount up and work with my C101 or my 312-8. I bought this off of a friend that thought it was from a 520, but after checking the model number it is for the 5XI series. If someone could let me know I would appreciate it. Thank you, Mike (case442) Share this post Link to post Share on other sites
mavfreak 11 #2 Posted April 21, 2011 can't help you on that mike, but if you have it then just try and see if it fits, wouldn't hurt :thumbs: Share this post Link to post Share on other sites
Kelly 1,035 #3 Posted April 23, 2011 I just bought a very nice 48" blade for a XI a few days ago, I think it will work, but you will have to remove the lift set up they has as it lifts in the front using the front attach matic for the pivot point, and you will have to weld a tab on the center cross bar to use as a lift point like the older blades, I think the frame is longer but that shouldn't be a issue, the handle is kinda funky but does use a nice cable to release the pivot pin. Share this post Link to post Share on other sites
