wheelly 0 #1 Posted April 21, 2011 I bet everybody has a beater. This was put together with alot of misc. parts. It is acually a 656 frame with some things from everything. Got board today so i decided it needed duals all the way around. I took it through the swamp today with the only problem was the belt slipping when it is under water. I thinking a stronger spring on drive belt. Share this post Link to post Share on other sites
littleredrider 409 #2 Posted April 21, 2011 Put enough air in the tires it will probly float!!!!! How did you do the fronts? Just long bolts?? Share this post Link to post Share on other sites
wheelly 0 #3 Posted April 21, 2011 I made wheel spacers then used allthread rod for bolts. It also likes to climb over fallen trees alot better. Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted April 21, 2011 Might want to add a air cleaner. Share this post Link to post Share on other sites
n1defan 47 #5 Posted April 21, 2011 Or even a breather tube like on a Jeep. :thumbs: Share this post Link to post Share on other sites
Shuboxlover 484 #6 Posted April 21, 2011 How well does it steer with four front tires? :thumbs: Share this post Link to post Share on other sites
corn53 4 #7 Posted April 21, 2011 :thumbs: Cool? :wh: Share this post Link to post Share on other sites
JC 1965 1,541 #8 Posted April 21, 2011 :wh: Looks like that would be fun to play with. :thumbs: Share this post Link to post Share on other sites
tgranthamfd 29 #9 Posted April 21, 2011 That's the first time I have seen dual fronts. Cool. Share this post Link to post Share on other sites
Coadster32 793 #10 Posted April 21, 2011 Cool pics, like the dually setup! Call up Exibit and have him pimp your ride! :wh: Share this post Link to post Share on other sites
wheelly 0 #11 Posted April 21, 2011 It steers just fine. The outside tires on the front are 1 inch smaller in diameter so they are not carring much of a load until u need them. Share this post Link to post Share on other sites
