fdsinozich 1 #1 Posted April 18, 2011 I have a C-120 auto (1-0495) with a 42" deck # 5-1010. The parts diagram calls for belt #1594 (1/2" X 107). I purchased this belt and it is a mile too long. Which belt will fit? Thanks, Frank Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted April 18, 2011 Did you mount it correctly ? ? ? Look at this pic of a 42" deck... Attached Image Share this post Link to post Share on other sites
daveoman1966 3,882 #3 Posted April 18, 2011 One drawing show the spindle belt as # 1594 for a 42" deck and another dwg says to use belt # 6738. #6738 is only 86" long. Here is the schematic Attached Image (Click thumbnail to expand) Share this post Link to post Share on other sites
mcwh1950 2 #4 Posted April 18, 2011 Frank If you're using the ipl from toro for your deck 5-1010 it's a little misleading.This ipl is really deck 5-1210 for a 48 " deck. If you go all the way down on the left side pass part number 111 you will see that the part number start over. These are the part number that you want to use for the 5-1010. The spindle belt is number 40 part number 6738. 86" long by .05 . I hop this is not confusing to you. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted April 18, 2011 Remember this?: http://www.wheelhorseforum.com/index.php?showtopic=27170 (look at #40 on the IPL again) :thumbs: Share this post Link to post Share on other sites
fdsinozich 1 #6 Posted April 18, 2011 Turns out it is the 86" belt. Thanks to all. Frank Share this post Link to post Share on other sites
