KB9LOR 4 #1 Posted April 7, 2011 Need part # 9733 "O" ring for my hydraulic lift cylinder, it goes on the inlet and outlet hoses, anyone have the correct size they should be? Thanks! Share this post Link to post Share on other sites
Trouty56 565 #2 Posted April 8, 2011 My guess would be this....3rd one down for #5 SAE ORB. http://www.discounthydraulichose.com/Viton..._ORB_p/4001.htm Hope I am right. :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #3 Posted April 9, 2011 Does anyone have the size "O" ring that goes on the hoses that go to the lift cylinder? Share this post Link to post Share on other sites
Trouty56 565 #4 Posted April 9, 2011 Still a little blurry but maybe this will help.... Sticks are in focus.....lol Looks to be 9/16 inch...1/16 inch thick. Share this post Link to post Share on other sites
KB9LOR 4 #5 Posted April 9, 2011 Thanks Bob, that is what I needed!!! much appreciated! Share this post Link to post Share on other sites
KB9LOR 4 #6 Posted April 12, 2011 Okay lift hose leaking AGAIN!...does anyone have any of those "O" rings? the ones I have tried are either too thin or something, I have tried numerous amnufacturers to no avail, Parker, Cheapo's, you name it, all with NO luck! anyone??? P.S. Are they still available from TORO? Share this post Link to post Share on other sites
JimD 3,345 #7 Posted April 13, 2011 I know IndyWH carries some hydraulic gasket and other parts, have you checked with him? Share this post Link to post Share on other sites
Indy w h 4 #8 Posted April 13, 2011 Need part # 9733 "O" ring for my hydraulic lift cylinder, it goes on the inlet and outlet hoses, anyone have the correct size they should be? Thanks! Does it leak when the engine is off ?? Or is it just an under pressure leak ?? Let me know !! Indy Share this post Link to post Share on other sites
KB9LOR 4 #9 Posted April 13, 2011 Need part # 9733 "O" ring for my hydraulic lift cylinder, it goes on the inlet and outlet hoses, anyone have the correct size they should be? Thanks! Does it leak when the engine is off ?? Or is it just an under pressure leak ?? Let me know !! Indy It was leaking as it sat not running. before I took it out I noticed the deck had dropped down. Share this post Link to post Share on other sites
Indy w h 4 #10 Posted April 13, 2011 Need part # 9733 "O" ring for my hydraulic lift cylinder, it goes on the inlet and outlet hoses, anyone have the correct size they should be? Share this post Link to post Share on other sites
KB9LOR 4 #11 Posted April 14, 2011 Need part # 9733 "O" ring for my hydraulic lift cylinder, it goes on the inlet and outlet hoses, anyone have the correct size they should be? Share this post Link to post Share on other sites
