chevy030303 0 #1 Posted April 7, 2011 Would anyone have a picture for the speed cabel on the motor? :thumbs: Share this post Link to post Share on other sites
rmaynard 16,694 #2 Posted April 7, 2011 Would anyone have a picture for the speed cabel on the motor? What engine on what tractor? Share this post Link to post Share on other sites
chevy030303 0 #3 Posted April 7, 2011 its a kohler 8hp k181 on a 1967 857 Share this post Link to post Share on other sites
rmaynard 16,694 #4 Posted April 7, 2011 Do you need to know what it looks like, how it is routed, how it attaches to the engine, or all of the above? I have an 856 which is similar that I can take a couple of pictures, but it won't be until later tonight or tomorrow. Maybe we can get Stevasaurus to take a couple pictures of his 857 cable for you. Share this post Link to post Share on other sites
chevy030303 0 #5 Posted April 7, 2011 i need to know how it hooks on to the governer and how it looks Share this post Link to post Share on other sites
stevasaurus 23,516 #6 Posted April 10, 2011 Here ya go 3030...hope this helps. First one has throttle in and the second with throttle out. Share this post Link to post Share on other sites
chevy030303 0 #7 Posted April 10, 2011 :thumbs: thanks man, Now how loose should the nut be? Share this post Link to post Share on other sites
stevasaurus 23,516 #8 Posted April 11, 2011 the nut should be tight...so it does not slip on the protruding shaft. That is where your adjustment should be. I am really not sure how to do that yet. Hope someone else chimes in. I really have not been there yet. All I can say is the first picture shows the throttle closed, and the second open...I know there is more to it...just have not done it yet. To tell you the truth, I hope some one comes in here and explains the process. There is a "Pinned" section on Kohlers floating around here. The information is in that. Check the pinned stuff in the tractors section. :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #9 Posted April 11, 2011 If you're talking about the brass bushing nut that's screwed into the engine block, it gets torqued @ 70-90 INCH lbs. If the control disc binds when the brass nut is tightened, check the cable housing bracket and make sure it isn't bent outward against the back side of the control disc. Share this post Link to post Share on other sites
GMCman 0 #10 Posted April 11, 2011 Looks like we have something to do tomorrow :thumbs: Share this post Link to post Share on other sites
chevy030303 0 #11 Posted April 11, 2011 yuppers :thumbs: Share this post Link to post Share on other sites
Kelly 1,035 #12 Posted April 11, 2011 you guys are brothers??? Share this post Link to post Share on other sites
chevy030303 0 #13 Posted April 11, 2011 :thumbs: no great friends tho :wh: Share this post Link to post Share on other sites
