Actonhorse 26 #1 Posted April 5, 2011 I have been searching the transmission section and have seen lots of rebuilds that have been helping alot. I am rebuilding the 5060 trans out of my 1067. I tried to flush it several times and the gear oil kept getting nice and milky after about 1/2 hour or working so I decided once the snow stopped to clean it out. I have it all torn down and cleaned and am ready to put it back together. My problem is that the needle bearings in the ends of the axle stubs won't come clean and are fairly pitted from the tractor running without seals on them for quite some time and need to be replaced. I have found them but am not quite sure how they are removed... Can anyone give me a good idea how to get them out without damaging the case? Here is a pic as I know how much you all love them! Attached Image Share this post Link to post Share on other sites
Actonhorse 26 #2 Posted April 5, 2011 And one of the "before" Attached Image Share this post Link to post Share on other sites
racinfool40 203 #3 Posted April 5, 2011 What I do is-- Since there junk anyways I take a small screw driver and drive it between the bearing and the trans case and collapse the bearing in on it self..Take a pair of needle nose pliers and pull it out.. :thumbs: Share this post Link to post Share on other sites
WH854 45 #4 Posted April 5, 2011 If I did it I would find me a 8 or 10 inch piece of plastic pipe that would fit inside the roler bearing and drive it out(might work, might not) Chas Share this post Link to post Share on other sites
dgjks6 8 #5 Posted April 5, 2011 I used a scoket on an extension. I was small enough to fit through, buit big enough to push it out. Also you can use it put the new bearing in. Share this post Link to post Share on other sites
Actonhorse 26 #6 Posted April 5, 2011 Thanks, I will give it a shot and let you know how I make out... Share this post Link to post Share on other sites
sorekiwi 761 #7 Posted April 5, 2011 I used a scoket on an extension. I was small enough to fit through, buit big enough to push it out. What he said! ^^^^^ Share this post Link to post Share on other sites
pfrederi 19,806 #8 Posted April 5, 2011 Sort through your collection of washers. I have saved up a bunch that are near bearing size. That a hammer and a drift pin an you are in business. Share this post Link to post Share on other sites
can whlvr 994 #9 Posted April 6, 2011 hey dean,i use different sizes of hard wood dowels,they wont hurt the case and i have a small wood lathe that i can make my own sizes,one day i will buy a bearing seating kit though Share this post Link to post Share on other sites
