meadowfield 2,808 #1 Posted April 4, 2011 ...Do horses weigh? Just checking up on the weights before we starting hauling ours around the shows. We are running unbraked trailers for weight purposes and our max weight is limited to 1650lbs or 750Kg. So we have a B-111 (1979), a Raider 10 (1972) and a C-101 (1979). All 3 have no cutter deck or unnecessary ancillaries. Does anyone know the individual weights for these tractors or can anyone point to a link which might help us. We will put them on the weighbridge in a few months time, but will have to load 3 on to get us there... thanks mark Share this post Link to post Share on other sites
mavfreak 11 #2 Posted April 4, 2011 they're around 500 to 600lbs a peice best I can guess Share this post Link to post Share on other sites
meadowfield 2,808 #3 Posted April 4, 2011 Thanks, just looked in the OM for the C-101, it says 590lbs (270Kg) I guess with the cutter deck removed it will be around 520lbs - the deck is heavy ! Share this post Link to post Share on other sites
mavfreak 11 #4 Posted April 4, 2011 Its is pretty safe to say they'll all be around that...sorry that doesn't help much...I did a search on RS cause I pretty sure I've seen someone post this answer at one time but I just am not able to find it. Share this post Link to post Share on other sites
ol550 831 #5 Posted April 4, 2011 Try TractorData.com Share this post Link to post Share on other sites
tgranthamfd 29 #6 Posted April 4, 2011 If you have access to any of the tractors manuals, they have the weights in the specification sections. I downloaded a couple of mine from Mikes website. Share this post Link to post Share on other sites
stevasaurus 23,455 #7 Posted April 4, 2011 here is a link to MikesRJ's site: http://www.mywheelhorse.com/modules.php?na...show_doc&id=110 as was stated...the weights are printed in the manual. All tolled with what you are talking should be under 1,500 LBS but I would think over 1,200LBS. :thumbs: Share this post Link to post Share on other sites
can whlvr 994 #8 Posted April 6, 2011 is that the total weight including trailer,over here in canada you have to include trailer weight also,but we have a much higher non brake limit than yours,u can buy trailers rated to be 3500 lbs(including trailer)with no brakes,i have three trailers one has no brakes the others do,i like the no brakes for some things,no messing around with brake systems Share this post Link to post Share on other sites
B-8074 20 #9 Posted April 6, 2011 Also the manuals state that it is the dry weight. Share this post Link to post Share on other sites
