Cessna 1 #1 Posted April 4, 2011 I took my mower 42' deck (side discharge) apart last fall after hitting a pipe while shredding leaves. My tractor is a Workhorse 1142. After welding the patches and replacing the baffles on the deck it is time to put it together. Is there a diagram showing where all of the parts go? I want to make sure that I will have it assembled correctly. Share this post Link to post Share on other sites
C-Series14 15 #2 Posted April 4, 2011 One trick is to always take a pic of the piece of equipment you are taking apart! But, for diagrams, go to the section "Wheel Horse Tractors" and at the top where the stickies are, there is one called "links" and there is the Toro site and then under "parts suppliers" there are several more that have parts diagrams. I use sepw.com You will need your VIN number off the deck or someone here will give you one if you need one... Share this post Link to post Share on other sites
Shuboxlover 482 #3 Posted April 4, 2011 this should help https://lookup3.toro.com/Ill/1x/5/5410/86R10052.gif https://lookup3.toro.com/Ill/1x/5/5410/86R10056.gif https://lookup3.toro.com/Ill/1x/5/5410/86R10054.gif Share this post Link to post Share on other sites
