ThreeHorses 20 #1 Posted April 3, 2011 93 520 with hydo drive and lift. Lift will only work part of the time. Part of the time works OK, other times not at all or slow. What to look for to fix? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #2 Posted April 3, 2011 Did you check the fluid? Share this post Link to post Share on other sites
ThreeHorses 20 #3 Posted April 3, 2011 Fluid is full. Will work OK then not work, then just start working, then quit. Could it be air in the line, sticking valve or ? Share this post Link to post Share on other sites
repairman 7 #4 Posted April 3, 2011 CHECK THE LINES TO THE VALVE MINE WAS SLIGHTLY PINCHED AND CAUSING INCONSISTENT LIFT OPERATION EASY SOLUTION NOW THE BAD A CHARGE PUMP CAN BE DIRTY OR WORN INSIDE CAUSING WEAK CHARGE TO OUTPUT LINES WOULD HAVE TO TEST LINE PRESSURE BUT YOU WILL NEED THE EATON MANUAL TO SEE WHAT THIS SHOULD BE CHECK TORO WEB SITE FOR THIS MANUAL. Share this post Link to post Share on other sites
